Author Topic: Photos PoorBoy Gators  (Read 1054 times)
j mullins
  • Guest
« on: June 06, 2011, 12:59:08 pm »
Here is a simple way to protect your down tubes from getting rock dings and it will keep dirt and debris out of your fork seals.  It takes about $1.00 worth of pipe insulation zip tied to the fork tubs   8)
« Last Edit: June 06, 2011, 01:01:12 pm by JDM »
Re: Photos PoorBoy Gators
« Reply #1 on: June 06, 2011, 02:04:22 pm »
I take it that they must be loose enough and short enough to allow for the fork movement? A pretty slick idea!
j mullins
  • Guest
« Reply #2 on: June 20, 2011, 12:44:07 pm »
This will save your fork seals and you will not even know they are there.
Offline jathkajoe
  • COG#: 11141
« Reply #3 on: July 09, 2011, 03:08:28 am »
Same stuff I use to block the vent in my Rifle windshield base when the rain is pouring in through it. Also use it to plug the holes in the wind scoops if I want warmer feet.
Ride safe, all
Joe
