Author Topic: Photos Poorboy Wheel Balancer  (Read 2867 times)
j mullins
  • Guest
« on: May 23, 2011, 01:44:22 pm »
For easy balancing, the yellow dot (sometimes white) should be lined up with the valve stem. To find the heavy side, gently spin the wheel and then let it come to rest. Heavy side will be at bottom. Then add weight to the light side. Spin again. If it stops at the same place, add more weight to the light side.  Repeat until it does not stop in the same place twice.  The tire is balanced.   The key here is using the spindle bolt on any flat surface.  It is also a good way to check your bearings. JD
Offline Colin
  • I'd rather be riding!
    • Facebook
Re: Photos Poorboy Wheel Balancer
« Reply #1 on: May 23, 2011, 02:01:02 pm »
Nice JDM!
Typically Connie Frugal LoL :)
Can you write it up and send to Slybones to post up as a Tech Article?
Selling my ZGRX - C10 with a ZRX1200 Engine - Details Here
Colin Prior
j mullins
  • Guest
« Reply #2 on: May 24, 2011, 01:03:12 pm »
Colin, if we generate some interest I can do that.  You be the judge.  HTH JD
Offline Ctchrisf
  • COG#: 9726
« Reply #3 on: May 24, 2011, 09:04:45 pm »
whats the sensitivity of that? galv pipe isn't the smoothest surface.
nice thinking though.  ;)
« Reply #4 on: May 24, 2011, 09:10:09 pm »
Doesn't matter, he is just using them to hold up the axle. The axle does not move, the wheel turns on the bearings. At least I think that is what he is doing, I have done that in the past but now I just use Dyna Beads from Innovative Balancing.
« Last Edit: May 25, 2011, 11:06:00 am by WillyP »
Offline doug
  • 'On The Road Again.. just can't wait..'
  • COG#: 9344
« Reply #5 on: May 25, 2011, 04:12:56 am »
Doesn't matter, he is just using them to hold up the axle. The axle does not move, the wheel turns on the bearings. At least I think that is what he is doing, I havwe done that in the past but now I just use Dyna Beads from Innovative Balancing.
+1 on the Dynabeads! Love them so far!
ConRad the Concours... 2006 C-10 new to me 10/21/2010. 3,1xx miles old at purchase! "Blessed beyond reason"   COG #9344  CDA#0334
j mullins
  • Guest
« Reply #6 on: May 25, 2011, 02:42:03 pm »
This is still a good way to check your wheel bearings for burnelling.  HTH JD
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
« Reply #7 on: May 25, 2011, 03:26:10 pm »
OMG is that a 491!  Yikes!
j mullins
  • Guest
« Reply #8 on: May 25, 2011, 09:10:27 pm »
2linby, don't come back with a yikes. I am getting ready for a 10,000 to 12,000 mi trip, maybe more; 6 weeks on the road and wouldn't have any thing else.  These tires are as good as you can get in a long distance tire. Good for about 20,000 mi with a load. Have you ever run these tires? I get a feeling you have not, but if you know something more about these tires, I would like to know. I have a extra set of wheels for the Connie.  I run a softer tire here in northwest Arkansas when I want to run the twisties. These 491s will come off when I get back and be hung back up in the rafters of the shop.  It is getting hard to find tires for the Connie especially when you are traveling.  And if you do find them, you are going to pay out the a$$ for anything you find. Been there. Remember I am an Old Fart.  Want to race? :)  JD
« Reply #9 on: June 05, 2011, 04:20:57 pm »
Don't pick at his invention. It works!
We built a very similar ballancer to rebuild/balance all the rotating parts in a Model T Ford Engine and transmission.
Ours was bit more refined as we used some knife edged steel for the beams to reduce friction, and a bubble balance to get it perfectly level.
We found that Originally all the T parts were "badly" out of balance.
Did a lot of grinding and everything is now balanced.
One of the items that we balanced was the Model T Flywheel. (58+ lbs)
To  start the project We chucked it in a lathe and cut off 7 lbs.
We then drilled holes to do the balance....
NOTE: Our homemade balance was accurate enough that we could change the balance with the weight of 1 BB.
Out of curiosity we sent the flywheel to a speed shop and had it properly balanced.
We found that our homemade balance was incrdibly close to the finished/digital/spin balance.   8)
In addition to our balance,,, we bored the engine, decked the block, added a higher lift cam, shaved the head  (0.125"), 3 angle valve job, hard faced the seats, and replaced the pistons and rods with MUCH lighter ones. We then balanced all the pistons and rods.
Now, I know some will ask why we did this?
My answer is if you ask such a question,, you will never understand!  :P
With a bit of luck, our 21 hp engine may produce 27...  And it will do it smoothly   :))   WOW!!!!!!
Offline Colin
    • Facebook
« Reply #10 on: June 05, 2011, 06:08:56 pm »
Way to go Ted!
Now had you put a C10 engine in there I would have been impressed  ;)
Colin Prior
« Reply #11 on: June 05, 2011, 09:36:29 pm »
Colin, your gonna laugh at this.
In a T some install a gearbox (Warford) behind the T Transmission to split the gears. (Low/std/overdrive)
Unfortunately, Such a transmission costs a bundle!
Being a tinkerer, I've been building my own by using the gears out of a motorcycle.
I doubt I will ever do it,, but can you imagine the # of gear choices I would have....
Offline Zorlac
  • COG#: 6962
« Reply #12 on: June 05, 2011, 10:18:01 pm »
Hey Ted, any chance Chuck is going to take you up on your offer to trailer his Connie to the national in VT?
Just don't use the T for the tow vehicle.  ;D
Mark.
COG #6962
« Reply #13 on: June 06, 2011, 02:32:21 am »
Actually we haven't talked about me taking his bike with me as I may not be going.  :'(
Unfortunately, the T might have to be the Tow vehicle.Explanation:
The trip may be a canx for me.  Someone stole my Avalanche last week..    >:(
Arghhhhhhhhhhhhhhhh  >:(
At this point my only option to go  is to Fly there and "try" to find a bike to ride...
QUESTION:: Is anyone willing to let an OtP guy (ME) borrow a bike fer a day while we're at the NATIONAL????????
(So I can ride with the Travelers)            I'm honest and trustworthy!!    :)
« Reply #14 on: June 06, 2011, 07:51:35 am »
Don't give up hope just yet!
Offline Zorlac
  • COG#: 6962
« Reply #15 on: June 06, 2011, 12:55:30 pm »
Wow Ted!
I'm really sorry to read about your Avalanche being stolen, that sucks!  :-\
Hope it's recovered OK.
COG #6962
« Reply #16 on: June 07, 2011, 04:08:31 pm »
Yah, me too.
Getting back to his Wheel balancer,,,,, I may balance mine the same way he did his.
Looks like a good option.
