Author Topic: Rear shock absorber settings  (Read 241 times)
Offline Fuzz
  • "Aloha, my name is Mr. Hand."
« on: June 26, 2020, 09:18:35 pm »
Manual states nothing about settings for rear shock absorber.
Does some one have a general PSI range for say ‘sporty and stiff’ to soft and cushy?
I am familiar with measuring sag and adjustments.
"This is U.S. History. I see the globe right there!"
Re: Rear shock absorber settings
« Reply #1 on: June 26, 2020, 09:34:17 pm »
Probably best to go by sag.  You can tweak from there.  I'm sure there will be an abundance of opinions to follow.......and mine is worth what you paid for it! ;)
2013 Kawasaki Concours 14
« Reply #2 on: June 26, 2020, 09:44:53 pm »
For normal riding,
I liked about 40 PSI.
For Sporty, I went up to 50 PSI..
At those pressures, Sag will still be a more than 35mm, but closer at 50.
I think I used 2 on the damper adjustment.
On the front, the springs are too soft to get near 35mm regardless of how much preload you add.
At the rear, I've gone to a C-14 shock and cranked in a lot of preload.
I stiffened the front by shortening the front spring 4" {added a 4" spacer} and added an Emulator to give more adjustability.
  • Stayin' for the people....
« Reply #3 on: June 26, 2020, 10:32:35 pm »
I used the middle setting on the damping, and 20-25 psi air.
I was a svelte 210 at the time.
Loaded for a trip about 40 psi.
As Ted said, the OEM suspension on the C-10 is 'soft' by today's standard.
I eventually did similar upgrades as Ted.  Straight rate springs and emulators
up front with a C-14 rear shock.
The factory set up delivers a very comfortable ride.  The upgrades will
sacrifice some of that comfort for performance/stability.
Offline Fuzz
« Reply #4 on: June 27, 2020, 01:00:23 pm »
Appreciate the input. Will any year Concours14 rear shock fit the 2006 ZG1000?
« Reply #5 on: June 27, 2020, 03:43:21 pm »
Any year C-14 shock will fit with some simple modifications, but it will raise the rear about 1 1/2".
Many install a lowering Rocker or Lowering Link to make it level again.
Others have installed a ZZR-1200 rear shock as they also fit, require the same simple mods, and do not raise the rear of the bike.
Bike will be only slightly taller than stock.
« Last Edit: June 28, 2020, 12:01:42 am by connie_rider »
Offline HPazzoto
  • COG#: 13148
« Reply #6 on: June 28, 2020, 01:30:02 am »
I adjusted the SAG on mine a few hours ago, and came up with these numbers:
Traseira (Rear)
L1:  15-1/4”
L2:  12-13/16” ;  13-1/2” ; 13-1/4” ; 13-3/4”
L3:  12-1/2”     ;  13-1/4” ; 13-1/16” ; 13-1/2”
Final: 1-5/8” (1.625 ; 41.275mm) @ 50 psi and damper on 4.
Dianteira (Front)
L1: 3-11/16”
L2: 1-9/16” ; 1-13/16” ; 2
L3: 1-3/4”   ; 1-3/4” ; 1-3/4”
Final: 1-13/16” (1.8125 ; 46.0375mm) @ 3/4 turn from fully “closed”.
I am a “strong” guy with just 270 lbs. And a Givi trunk...
As y’all can see and imagine, it improve handling and stability a lot.
« Reply #7 on: June 28, 2020, 02:00:24 pm »
HPazzoto;    Is the L1 on the front taken with the wheel off the ground?
                        Seems to be a unusually small number.
                  Do you have all your preload cranked in, in the front?
                        A C-10's front springs are weak. With your weight, you will need all the preload you can get.
                        Your front sag of 46mm is almost 1/2 your available sag. That leaves little travel to absorb bumps.
Target sag for both ends should be 35-40 mm..
Offline HPazzoto
  • COG#: 13148
« Reply #8 on: June 28, 2020, 02:19:29 pm »
Hi Ted. Yes, both wheels off ground for L1. On the front I measured from lower triple clamp to top of fork cover...
And on the front it’s almost all cranked in: I fully screwed in and backed out only 3/4 of a turn. When adjusting I felt a huge drag on the front fork, and also looking at L2 and L3, I can tell it needs service. Same goes for the rear shock...
I’ve looked here in the forum and at the end of the year I’ll service/mod both suspensions. The rear ZZR1200 shock seems like a good option, and for the front a different spring rate with emulator...
For now I’ll just enjoy it the way it is and try to avoid potholes as much as I can, while the weather is still good for riding...
« Reply #9 on: June 28, 2020, 05:17:54 pm »
Some say the ZZR shock has soft springs too.
I'm unsure. Think you'll be ok with just cranking up the preload.
  I'm using a C-14 shock and a lowering Rocker. {As I already had the Rocker and a C-14 shock}
On the front, I was too tight to buy aftermarket spring.
I just removed 4" {of the tightly wound coils} from a stock spring, and dropped in a 4" PVC spacer.
Stiffens it up nicely. Costs nothing.
