Author Topic: Rear suspension and air pressure  (Read 776 times)
Offline Ironwood
  • COG#: 12031
« on: March 31, 2018, 03:51:10 pm »
Model 2000 - just lubed the 3 lower zerks on the linkage and I CANNOT get to the 2 on the upper "dog bones" zerks without taking off the mufflers.
So, I'm going to switch them out of 90 degrees ones. Anyone know the correct size that will replace (just didn't want to take them out and find out a have to order the 90's).
Also, just going through the FSM and it states to NOT check the rear shock pressure with a "tire gauge".  Uhh....options?
Member # 12031
2000 ZG1000
Offline PdD
  • COG#: 11905
Re: Rear suspension and air pressure
« Reply #1 on: March 31, 2018, 11:12:57 pm »
The grease zerks are 6 mm and I always got by using a tire pressure gauge on my rear shock until I replaced it with a Progressive shock.  I either used a digital gauge or one made for lower pressures like one for ATV tires.  I think as long as you get a good seal between the valve and the gauge you should be fine.
He who walks with the wise grows wise, but a companion of fools suffers harm. Prov.13:20.
Offline Ironwood
  • COG#: 12031
« Reply #2 on: April 01, 2018, 12:57:12 am »
Thank you...appreciate it the help!
Member # 12031
2000 ZG1000
Offline JPD
  • COG#: 12064
« Reply #3 on: April 01, 2018, 02:59:21 am »
The reason to not use a tire pressure guage is that the volume of air in the shock is so small that each time you check it you loose a lot of pressure. Bike tire pump with a clip on nozzle and guage or compresser with a good regulator, set to the pressure you want.
Offline JohnJuan
« Reply #4 on: April 17, 2018, 04:16:03 pm »
I have the Harley Touring Suspension air pump, and it works great.
https://www.harley-davidson.com/store/touring-suspension-air-pump
