Author Topic: Revisiting Emulators  (Read 1376 times)
Offline fish
  • COG#: 11285
« on: February 14, 2018, 11:16:59 pm »
Yea I know it's been discussed way back when, but after reading them , I'm a little confused at some answers. In one it says to drill the emulator from 2 hole to 4, ? Are you talking the actual emulator or the emulsion tube that the emulator sits on top of. Was thinking of cutting stock spring on my 03 4 1/2 inches & installing spacer & adding emulator.
Thanks ,
COG # 11285
CDA # 518
IBA # 47424
2003 Concours
2009 Goldwing
Offline GeorgeRYoung
Re: Revisiting Emulators
« Reply #1 on: February 15, 2018, 01:10:42 pm »
Emulator install blurb:
http://web.ncf.ca/ag136/forkUpgrade.htm
There's also an option to drill holes in the emulator blowoff plate:
http://www.zggtr.org/index.php?topic=1627.msg17773#msg17773
« Last Edit: February 15, 2018, 01:21:33 pm by GeorgeRYoung »
Offline fish
  • COG#: 11285
« Reply #2 on: February 15, 2018, 10:34:44 pm »
Thanks , shame the pictures don't show up
COG # 11285
CDA # 518
IBA # 47424
2003 Concours
2009 Goldwing
Offline PdD
  • COG#: 11905
« Reply #3 on: February 22, 2018, 12:20:16 am »
I just put Race Tech springs and emulators in this winter. The emulators I received already had 4 holes drilled in them from the factory.  Each damping rod gets 2 more holes drilled all the way through. I included a picture of the damping rods modified and unmodified.
He who walks with the wise grows wise, but a companion of fools suffers harm. Prov.13:20.
« Reply #4 on: April 07, 2018, 03:53:36 am »
  I did the emulators setup on my front forks many years ago and I got lucky!! I didn't screw it up.  >:(  Really happy with the results on my '94!!  :)
« Reply #5 on: April 07, 2018, 11:04:39 am »
The extra holes in the blow off plate are to aid low speed compression damping. because there's not real rebound damping (done by oil weight, around 30 wt) there needs to be a way to soften the low speed compression damping. High speed damping happens when the valve blows open. HTH, Steve
Online MAN OF BLUES
« Reply #6 on: April 07, 2018, 06:16:47 pm »
If you click on the photobucket hosting place holder thing, it will take you to the photo...
Or you can download a patch for Chrome that allows the pics to shsow, but simply clicking the photo placeholder still works...
