Author Topic: Roving front wheel  (Read 244 times)
Offline alex9078
  • Liven the Dream
  • COG#: 11853
Roving front wheel
« on: August 12, 2017, 09:04:24 pm »
What size Allen wrench do I use to remove front wheel? 11mm, 12mm,or 13mm?
Offline works4me
  • COG#: 10594
Re: Roving front wheel
« Reply #1 on: August 12, 2017, 09:11:17 pm »
12mm
Offline MichiGlenn
  • "Wherever you are, be all there" Jim Elliot
  • COG#: 10892
« Reply #2 on: August 14, 2017, 12:59:52 am »
You need 2 of them. Figured that out after buying one from amazon this week. Got mine off today.
2001 C-10
1977 Honda CB750K Sold
1978 Honda CB750K Long Gone
1972 Honda CL175 Ancient History
Heald Super Tryke 8hp, Wards T555 Trike
Online Bob_C_CT
« Reply #3 on: August 16, 2017, 10:11:11 am »
If you leave the axle pinch bolts tight on one side all you need is one Allen wrench on the loose side.
97 C10,ZRX Front, Meanie Rear
Offline Jim
  • Jim
« Reply #4 on: August 16, 2017, 11:32:10 am »
Or cut 1" off your Allen wrench and use that piece to hold the other side with a 12mm socket or wrench just in case your axle is stubborn and the pinched side can't hold it.
