Author Topic: SERIOUS Front End Swap  (Read 392 times)
Offline connieklr
  • COG#: 1608
« on: July 31, 2019, 02:45:22 pm »
Ya’ll are probably aware that the lower fork tree stems on most bikes can be removed from the lower brackets – the Connie is no exception.
I popped one out on an ’88 model fork bracket I had with ~10T pressure and a little bit of heat as a test run. A fella is coming by a little later today for a repeat on his stuff. He has a 1996 Triumph Sprint and is trying to drop in a 2006 GSXR Front end on his brother’s bike. Some machine work may be needed, but won’t know that for sure until after we get into it a little deeper.
Good info to know for those considering a really serious front end swap other than simply changing wheels.
Always something fun going on here. Until then, time to whack the grass.
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
GB Young Services, LLC
Offline m in sc
    • 2strokeworld.net
  • COG#: 13057
Re: SERIOUS Front End Swap
« Reply #1 on: July 31, 2019, 06:08:59 pm »
sweet. ive done quite a few swaps like this on other bikes. whats a decent modern ft end for the c10 to use? I do have capacity to machine (lathe/mill no problem).
Offline connieklr
  • COG#: 1608
« Reply #2 on: July 31, 2019, 06:28:12 pm »
Have no idea. I, and my own bike are too long in the tooth to even think about it.
I remember Dave Jakeman (now deceased) of Sagebrush Engineering worked up a swap for the KLR, changing the front end to a more "modern" cartridge type forks. He had to machine a tapered bushing to match a like taper in the lower adopted clamp to the straight shaft of the KLR. Not sure if we're going to run into that issue here, or not. Will find out later once the fella gets here and we get stuff pressed apart.
I'm a rank amateur when it comes to this type of machine work. No taper attachment for my 10L Heavy, but think we can manipulate the compound rest enough to cut a decent taper for a bushing if needed.
« Last Edit: July 31, 2019, 06:31:37 pm by connieklr »
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
