Author Topic: rear shock  (Read 2507 times)
Offline gwc
rear shock
« on: October 04, 2014, 02:20:13 pm »
on a 99 zg1000 does the rear shock have to leak to be bad? ways to tell if shock is bad or just needs to change oil?
« Last Edit: October 04, 2014, 02:25:05 pm by gwc, Reason: for got to list the year »
Offline gwc
rear shock
« Reply #1 on: October 04, 2014, 02:35:03 pm »
I have a 99 zg1000 my rear end is bouncy.....how can you tell if the shock is bad or if I can repair it.
Offline Trapshooter2
  • Trapshooter
  • Never allow your Dog to guard your food!
  • COG#: 11753
Re: rear shock
« Reply #2 on: October 04, 2014, 02:41:38 pm »
Have you pulled the right side cover to see if where the dampening adjustment is? Secondly, any idea if there is any air in it for the pre-charge?
I just purchased one of these off Amazon. Made adjusting the rear shock easy as pie. http://www.amazon.com/gp/product/B004Y18GKM/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
1998 ZG1000 (aka: The Green Hornet)
Re: rear shock
« Reply #3 on: October 04, 2014, 03:29:43 pm »
If the shock is not controlling the rear wheel like it should I would try changing the fluid, if that doesn't work, I would consider the shock bad.
I don't think you will know before you change the fluid, other than if it's leaking. I think worn out fluid will give the same results as worn out shock.
Re: rear shock
« Reply #4 on: October 04, 2014, 03:33:28 pm »
Merged 2 topics, same subject.
Offline DC Concours
  • 2001 Concours, ~25K miles
Re: rear shock
« Reply #5 on: October 04, 2014, 10:03:56 pm »
My rear shock is a little mushy. How do you change the oil in these shocks? I thought they were not serviceable. Bad ones need to be simply replaced.
Offline Strawboss
  • COG#: 5852
01 Concours  1982 KZ550A  1979 Triumph Bonneville  1995 Honda scooter 1982 CB125s 1980 BMW R-65  COG#5852  AMA Life 302525  NRA 9098599  SASS 28759
Offline DXZG1000
  • COG#: 11684
Re: rear shock
« Reply #7 on: October 04, 2014, 11:28:04 pm »
Yep, I highly recommend the Progressive rear shock.  Just put one  on my 01.  Never have to worry about air leaks or weak shock.
http://www.murphskits.com/catalog/product_info.php?cPath=1_97&products_id=85
2001 C10, PR3 front tire, Shinko 777 rear tire, Progressive rear shock and front springs, air box mod, SISF massaged carbs, exhaust cam sprocket, and 2 min mod. External oil filter adapter. Adjustable fuel gauge mod.
Offline DC Concours
Re: rear shock
« Reply #8 on: October 05, 2014, 12:42:24 am »
Never knew that. Your links makes it clear as day. Thanks.
What about the air? What makes the rear shock not hold air anymore and can that be fixed?
This.
http://www.murphskits.com/catalog/product_info.php?cPath=1_97&products_id=119
Or this.
  • Stayin' for the people....
Re: rear shock
« Reply #9 on: October 05, 2014, 03:02:42 am »
This.
Or this.
There are seals, and the obvious shrader valve.  If the air shock is over filled, it can blow
out the seals.  If the seals are blown, you can get a 2006 Rear shock cheap  ;)
or go with a pricier replacement.
