John, how much play are you getting? 1/4" It really doesn't seem logical that you would have play when you move the wheel back and forward, and not with the tubes, unless you have a problem with your wheel bearings. when I grab the sachions the movement is still there, but when I grab the crome for tubes that it is not there. How do your tires look? like new Do you have any wobble when you slow down? no wobble Ever hear any knocks when you go over a bump? yes With the wheel off the ground (and an assistant helping), place a long bar under the front wheel and lift it to see if you have play that way, too (have your assistant observe with a drop light). no good help as the wife has to keep up w the 2 and 4 yr old. Will try to get some help tomorrow Check all your fork nuts and bolts for proper tightness. Thorough investigation is needed to absolutely rule out a problem with the fork assembly. all looks good with the bolt tourqe When was it last serviced? about a year ago, but I just bought it and that is what the previous owner said How about your wheel bearings? they are in good shape Be safe. tks
