Author Topic: Suppliers for Replacement Front Fork Bushings  (Read 600 times)
Offline TL
  • COG#: 12806
« on: June 12, 2019, 12:32:07 am »
1988 Connie, need to replace fork seal and thought I might as well replace fork bushing while I have the forks apart. Can't find a complete bushing kit. Every site only shows the same one bushing still available (can't remember which bushing that is off the top of my head) and the other bushing has being unavailable. Where does one go for new fork bushings for the early Connie's?
TIA
Tim
1988 Connie
Re: Suppliers for Replacement Front Fork Bushings
« Reply #1 on: June 12, 2019, 02:30:14 am »
as you found, currently not available, I have a link to a sub, on another computer, and will provide that info sometime tomorrow..
sorry for the delay, I gotta go to bed, but hang tight, and don't pull them out until I give the link.
Offline TL
  • COG#: 12806
« Reply #2 on: June 13, 2019, 12:22:56 am »
Thanks much MAN OF BLUEs. Haven't started the tear down yet, just getting my ducks in row for any surprises that may be lurking.  ;D
1988 Connie
Offline rgmr250
86-93 Fork bushings
« Reply #3 on: June 13, 2019, 04:12:08 am »
I forget which thread it was in (JUST Found it, and posted there), but remember that it was mentioned that the fork bushings are no longer available for the 86-93. I don't know if they actually have stock, but RaceTech is listing them:
http://racetech.com/ProductSearch/12/Kawasaki/Concours%20ZG1000/1986-93
Inner: http://racetech.com/ItemInfo/160
Outer: http://racetech.com/ItemInfo/161
Anybody tried them?
I'm not in need of them, but had a link to them and thought I'd pass this on, just in case it was a possible source.
1993 ZG1000
Offline rgmr250
« Reply #4 on: June 13, 2019, 04:13:42 am »
Anybody tried them?
1993 ZG1000
Offline Lee
  • COG#: 12558
Re: 86-93 Fork bushings
« Reply #5 on: June 14, 2019, 12:41:04 pm »
Please note RT part numbers are the same for C10 fork bushings of all production years if memory serves. I used later Kawasaki bushes that were available still on my 87 fork based on this observation. No problems in 6k miles noted. Just a 2 cents comment perhaps in need of independent confirmation by others more knowledgeable. Worked for me though. Calipers showed no difference to my eye.
« Reply #6 on: June 14, 2019, 04:04:21 pm »
not having both side by side, to compare, I can't say for sure, especially for the lower one...
but surprisingly the op may be good...
the same top seal is noted for models from '99 down to '86
92049-1273 &  92049-1164,   92049-1338 & 92049-1347 ('94-'99),   so it would kinda make sense, about the diameter, not sure about the length tho.
Offline rgmr250
« Reply #7 on: June 14, 2019, 04:20:39 pm »
Yes, indeed, RaceTech is listing the same part #'s for both 86-93 and 94-06. Definitely need confirmation on the Racetech parts. I thought the forks changed starting in 94?
1993 ZG1000
« Reply #8 on: June 14, 2019, 04:26:07 pm »
thus my post above,
the forks changed, and I assume the bottom bushing also, as the damper rod changed configuration...
but the diameter of the upper tube did remain the same... then, I can't say what changes were done to the internal machining on the lower fork tube slider, as it changed also, twice since '94
« Reply #9 on: June 14, 2019, 05:27:31 pm »
we have to threads cuncurrently with same info, maybe we could get them combined... I'll ask...
http://forum.cog-online.org/concours-c10-zg1000-general-chat-and-tech/86-93-fork-bushings/msg670682/#msg670682
Offline CRocker
  • '02 C10 CDA # 416
« Reply #10 on: June 16, 2019, 11:25:33 am »
thus my post above,
If I remember correctly...All Balls lists the bushings for the '94 and newer only...I have used them on the forks for which they are listed...seemed okay to me...don't know how similar they are to older models...
« Reply #11 on: June 23, 2019, 04:29:33 pm »
It appears that the lower bushing may be different on the Earlier Concours.
This place offers the upper for all, but the lower is for 94 and up.
https://www.ebay.com/itm/Kawasaki-Concours-1000-ZG1000A-86-06-Fork-Bushes-Outer-Guide-Pair/282187624649?epid=1656192124&hash=item41b3b170c9:g:ECoAAOSwPCVX4zxJ
https://www.ebay.com/itm/Kawasaki-Concours-1000-ZG1000A-95-06-Fork-Bushes-Inner-Slide-Pair/282187624749?epid=1756904864&hash=item41b3b1712d:g:PRsAAOSwYIxX4zxN
Maybe, just change your upper?
or send them a note and ask if they can get you the lower..  (might be use in another bike)
Or buy the whole deal and hope for the best on lower bushings..
https://www.ebay.com/itm/Kawasaki-ZG1000-Concours-94-06-Fork-Seals-Dust-Seals-Bushes-Suspension-Kit/233199199598?epid=5027923042&hash=item364bc1656e:g:5UsAAOSwFdtXx5VT
