Author Topic: Tire help!!  (Read 4882 times)
Offline TNConnieRider
  • COG#: 12722
Tire help!!
« on: December 12, 2017, 02:11:48 pm »
Hello! New here but not to forums. I find them very helpful in sharing information. Anyway, years ago I owned a Concours and was probably my favorite bike of the many I have owned. Recently I had an opportunity to grab another...so I did! Love everything about the bike but tires. In first first round (1986), had the original Dunlop front and rear and them moved to Metzlers and were great. This bike (1995) recently had Michelin Pilot up front and Shinko Verge in the rear mounted. At speeds above 55mph the bike "floats" and is all over the road. I have adjusted pressure and still hate the ride. This is not a typical Connie.
Here is the question-anyone had experience with these tires? I know Michelin but not Shinko. Could it be an unfit marriage of brands? Could it be something else? I hate to scrap new rubber but will in a heartbeat when it comes to comfort, handling and safety. Otherwise the bike is as smooth as I remember
Thanks!
Honda MiniTrail 50, Yamaha GT 80, Suzuki TC 100, Yamaha DT 125, Kawasaki KZ 400 Ltd   Kawasaki KX 125, Suzuki RM250, Kawasaki ZX600,Kawasaki Concours C10 (#1) Suzuki Boulevard C50,Kawasaki Concours C10 (#2)
Offline Jim
  • Jim
Re: Tire help!!
« Reply #1 on: December 12, 2017, 02:28:41 pm »
Do a search on "Verge".  The tire has a lower load rating and some people suspect that's why they were experiencing problems (wobble) with this tires.  The Shinko 777 (Bias), however, has a higher load rating and performs well with a radial on the front so I wouldn't necessarily discount the brand.  I've run (4) 777 on the rear and PR3's on the front with no complaints.
Unfortunately, PR3's in the 18" size are discontinued.
« Last Edit: December 12, 2017, 02:34:00 pm by Jim »
Offline Warwgn
Re: Tire help!!
« Reply #2 on: December 12, 2017, 02:50:24 pm »
Dunlop E4's in Goldwing size and your good. I hate Shinko's have never had good luck with them......well not totally true the brand new Shinko I took off the front when I bought the bike has made my kids very happy as a tire swing :beerchug:
Re: Tire help!!
« Reply #3 on: December 12, 2017, 03:02:02 pm »
Yupp, several times,,, we've seen exactly the same complaint on the Shinko Verge when used on a C-10.
  • COG#: 12722
Re: Tire help!!
« Reply #4 on: December 12, 2017, 03:04:50 pm »
I started reading many of the posts after I submitted this one. Although I have always been a stickler for matching brands on F & R, I see a new rear tire under the tree for me at Christmas and will go from there. May be a matching Michelin or another brand. but that thing has got to go. I don't want to rename my Concours to Corvair!   :rotflmao:
Offline GeorgeRYoung
Re: Tire help!!
« Reply #5 on: December 12, 2017, 05:49:18 pm »
I've had good handling and mileage from a couple of bias ply Michelin Commanders, 150/80B16.
« Last Edit: December 13, 2017, 02:50:37 pm by ron203, Reason: (Oops - didn\'t modify. Sorry-multi-tasking rots the brain) »
Offline CRocker
  • '02 C10 CDA # 416
Re: Tire help!!
« Reply #6 on: December 12, 2017, 09:44:50 pm »
Regarding the PR3 18" Fronts...
True...they are discontinued...but...there are still plenty of the 120/70ZR18 PR3 Front tires in the warehouse...WPS part number is 87-9775...
Can't seem to find the 110/80ZR18...it must be gone... :(
  • COG#: 12722
Re: Tire help!!
« Reply #7 on: December 13, 2017, 01:32:00 pm »
What is the thought on mixing a radial and bias tire? Running Michelin pr4 up front.
Re: Tire help!!
« Reply #8 on: December 13, 2017, 01:48:41 pm »
The thought is that it's ok.  There are a number of guys that are running a radial front such as a PR3 with the Shinko 777 on the rear which is a bias ply tire.  I use the 777 on my GS1100GK and am happy with it.
Offline ron203
  • COG#: 9847
Re: Tire help!!
« Reply #9 on: December 13, 2017, 02:51:24 pm »
(THIS is what I meant to do...)
Last combo I ran was this Michellin (rear) and a BT-045 front, both bias ply. Very stable.
2014 C-14
2008 Goldwing
  • COG#: 12722
Re: Tire help!!
« Reply #10 on: December 13, 2017, 08:41:50 pm »
Upon further investigation, my current Shinko Verge is the same load rating as the original tires at 71W. So lower rating could not be the issue. Regardless, I'm overthinking this and going to order the Michelin Commander 2 or Michelin Scorcher 31.  Kawasaki originally mounted radials and I'm inclined to go that way but the choices seem to decrease and costs increase
Offline Kelly E
  • Geriatric Hooligan
Re: Tire help!!
« Reply #11 on: December 13, 2017, 09:38:11 pm »
I am running the Michelin Pilot Activ on the front and the Commander II with the 77H load rating on the back. I have run the North Cascades Loop with this set of tires and I am very happy with this combination. I ride pretty hard and pushed these tires to see how they would do and no complaints.
1994 Kawasaki ZG1000A-The Long Rider
1984 Honda VF700S Sabre-The Bike
1986 Honda CB700SC Nighthawk S The Hooligan Bike
Offline Bob_C_CT
Re: Tire help!!
« Reply #12 on: December 13, 2017, 11:35:33 pm »
Take a look at your motor mounts just in case one sheared off. That will make it seem like it is riding on marbles.
Re: Tire help!!
« Reply #13 on: December 13, 2017, 11:57:38 pm »
So, the Michelin Commander 2 and Michelin Scorcher 31 are radials, available in the correct sizes, and are rated for this weight?
I wasn't aware of other radials that were suitable?
Offline CRocker
  • '02 C10 CDA # 416
Re: Tire help!!
« Reply #14 on: December 14, 2017, 12:15:45 am »
Neither one is a radial...
Offline Jorge
  • COG#: 9297
Re: Tire help!!
« Reply #15 on: December 14, 2017, 01:28:44 am »
I used a Commander II on the rear of my C10. It handled well, was responsive, great mileage, and had good grip... on dry pavement. I experienced several slips on wet pavement, and especially on paint stripes. I replaced it with about 50% tread left.
I replaced with Avon 3D X-M. It took a little to break them in, and until then, they wandered some, but after that, they were great.
There are many that have had issues with Avons, and swear at them, not by them... just saying.
Hey guys... another tire thread - LOL
Glad you found another Connie :great:
Re: Tire help!!
« Reply #16 on: December 14, 2017, 01:49:35 pm »
Over the last year or so we've heard that both the Avon 3D X-M and the Shinko Verge have had handling problems.
I personally saw a problem with an Avon 3D X-M that was so bad I could see it anytime he got near traffic.
I think I recall that the verge is a Verge II?
So, {not counting those} are there any Radials still available for the front/rear of a C-10?
Re: Tire help!!
« Reply #17 on: December 14, 2017, 02:31:05 pm »
There's a Pirelli 110/80R18 Angel GT radial I'm using for the front. Until a better radial comes along for the rear, I'll be sticking with the Michelin Commander II.
Offline CRocker
  • '02 C10 CDA # 416
Re: Tire help!!
« Reply #18 on: December 14, 2017, 03:05:26 pm »
Verge II is not available in a 16" diameter...it's the original Verge...
Offline Jim Snyder
  • COG#: 7055
Re: Tire help!!
« Reply #19 on: December 14, 2017, 07:52:25 pm »
One of the often overlooked bias ply tires that handles like a dream is the Avon AM-26. They are available in stock Connie sizes (pre 94 and post 94 sizes). If you have any doubt about the handling ask Daytona Mike or anyone else who followed me through the twisties in Arkansas over the years.
  • COG#: 12722
Re: Tire help!!
« Reply #20 on: December 22, 2017, 12:10:21 am »
Mounted an Avon Storm 3D and broke it in today. Can you say ear to ear grin and bike felt just as it should and as I remember. Straight roads, tight turns, slow speeds or "slightly" over the limit felt GREAT.
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
Re: Tire help!!
« Reply #21 on: December 22, 2017, 12:20:38 am »
Good choice , I love mine  :motonoises:
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
Offline Greenie
  • COG#: 1019
Re: Tire help!!
« Reply #22 on: December 30, 2017, 11:14:41 am »
Be careful not to put too much weight on the Avon Storm 3D. We had the bike fully loaded to capacity and the rear tire developed a wobble. It's probably fine for regular use.
Offline MikeH_OH
Re: Tire help!!
« Reply #23 on: January 17, 2018, 02:36:32 am »
I love my Avon 3D's. I haven't rode with a "loaded" bike, nor do I push it like my GSXR track bike. They do everything I ask and have done it well over the last 7 thousand miles. Not as cheap as some but, I feel, well worth the money.
Offline Red Eagle
Re: Tire help!!
« Reply #24 on: January 17, 2018, 04:07:37 pm »
 :great:
+1 to what Jim Snyder says. Followed his lead and never been happier.
Bob Young
COG #5753
Bob Young   COG #5753 C-10 A-1 CDA#307
