Author Topic: tire width  (Read 975 times)
Offline mf-rabbit
  • COG#: 9851
tire width
« on: May 01, 2018, 09:40:50 am »
I've been reading quite a few post's about the 110-80-18 & the120-70-18 so I purchased a 110-80-18 ContiRoadAttack 3 for my 99 concours but when I received the tire and unwrapped it, It looks quite narrow where it seals to the rim (measures 2 1\2") not sure this will seal on my rim so today hopefully I'll be able to remove the old tire and check,If not today then tomorrow. Hopefully I didn't get the wrong tire----On with the adventure. ;D
        Roger
Offline ron203
  • COG#: 9847
Re: tire width
« Reply #1 on: May 01, 2018, 10:55:38 am »
I've read in the member library I think, that the C-10 front wheel is narrower than normal. I used a 120 and it sort of became a  "Vd" shape as it wore. I switched to 110's and they seated and wore normally. Good luck.
2014 C-14
2008 Goldwing
Re: tire width
« Reply #2 on: May 01, 2018, 04:03:42 pm »
I've seen mention of the 110/80-18 many times, but haven't installed 1 myself.
Anxious to see the replies.
« Last Edit: May 02, 2018, 12:59:13 pm by connie_rider »
Offline Pat and Sher in MA
  • COG#: 7670
Re: tire width
« Reply #3 on: May 01, 2018, 08:45:19 pm »
I've been running a 110/80-18 on my 2004 for a few years and they fit fine and wear just fine as well.
If you have trouble seating the beads due to the tire being slightly narrow you can try strapping around
the center of the tire. Best of luck and you'll enjoy the tire size.
Pat & Sher in Ma.  04 C10 Dark Angel,  87 Ninja 600RX, 79 KZ1300 (x2)
Offline mf-rabbit
  • COG#: 9851
Re: tire width
« Reply #4 on: May 02, 2018, 10:21:56 am »
So many things to do -so little time! Got the old tire off but didn't  have time to get the new one on but I should have time today after work. Once I got it off (120-70-18) and measured it (bead width) it was the same so it looks like smooth sailing-to be determined.
        Roger
