Author Topic: Why Shinko Verge Tires Wobble ( my opinion ) - Avon AM26 problem solved. PICS !  (Read 988 times)
Offline Bearcat
    • Automatic Garage Door Services
Hello all,
I came up with an opinion as to why Shinko Verge tires wobble.  I believe it's the rear tire that causes the problem.
These tires have only 1700 miles on them.  They always wobbled on rain grooves and expansion joints. I believe the scalloped tread design was the cause.
SEE PICS: (yellow lines) Where the scallops are.
I replaced both tires with Avon Roadriders AM26. WHAT A DIFFERENCE !  Wobble gone and turn in much better due to correct front tire size.
Offline Charliedog
Just curious, from what size front tire to what size front tire did you go?   I love a 130/70 front tire.
Offline Bearcat
I went with the stock 110 /80 /18  on the Avon.   The Shinko was 120/80/18.
Online m in sc
yup. love my avons too.
Offline CRocker
  • '02 C10 CDA # 416
Pretty sure it was a 120/70ZR18 Shinko Verge...it’s the only 18 inch option in the Verge...
Offline Bearcat
Yes you are correct.
Offline Bearcat
Offline CRocker
  • '02 C10 CDA # 416
I ran a couple of 120/70ZR18s...and, was amazed at how they handled heavy rains...
Offline Jim Snyder
  • COG#: 7055
Another satisfied customer of the AM-26. I have been telling folks for years about this tire and how well it handles. Maybe more folks will give it a try.
I passed your recommendation of the AM-26 to a young guy that I met here.  Last time I talked to him, he couldn't say enough good things about those tires.  Maybe I'll try a set of those next time. :great:
Offline Rideezdale
  • rideEZdale
  • COG#: 12728
Jim, I ready to replace my Avon storms on my c10 that I got 8k miles on.  I remember you saying you put Avon Spirits on your Fjr. I am trying to decide between the Avon  AM26 and the Spirits for my c10.  So with your experience with both tires what would you recommend?  Thanks in advance.
Dale
1973 Yamaha YZ80, 1977 Suzuki GS400, 1978 Suzuki GS1000E, 1983 Honda CB1100F, 1984 Yamaha Venture,  1987 Yamaha Venture, 1989 Yamaha FJ1200, 2003 Kawasaki Vulcan 1500 Nomad, 2000 Kawasaki concours
Online m in sc
ive been running them for years on smaller bikes, never occurred to me to run them on a big old tank like the c10 till I read Jims review.  :beerchug:
Offline bikerhawk
  • COG#: 9207
My wife's C10 is wearing the AM26's. Very, very good tires. I wouldn't hesitate to put them on my C10,  but I've already done the Mean Streak rear wheel conversion. I do like  the planted feel a good 170/60-17 gives me on the back.
Tom Hunt
Lawrence, KS - Kansas AAD - COG #9207, IBA #68392
1998 C10, 111k miles (mine)
1994 C10, 35k miles (SWMBO's)
2002 KL250 Super Sherpa
Offline Jim Snyder
  • COG#: 7055
Dale
On the C-10 I would go with the AM-26's. They are by far the best handling bias ply tire I have ever used. And they have no heavy feel as many others do. I like the new Spirits on the FJR but I am already getting some cupping.
Offline Rideezdale
  • rideEZdale
  • COG#: 12728
Dale
Thanks Jim, that's the direction I was leaning.  I appreciate your recommendation!  :great:
Dale
Offline Jim Snyder
  • COG#: 7055
Dale
Dale
You will be amazed how well they handle and they track well on the highway. These are not your daddy's bias ply tires. Let us know how you like them.
Offline Bearcat
Did I mention how much I like these tires.    :great:
I lived with those Shinko Verges for 1700 miles.    ::)
I believe the manual does say 120/70-18 but that would be incorrect for the rim width.
The correct and better handling size is indeed 110/80-18 as is mine and others experience .
 I have ridden on Goldwing size tires on a C10 and those tires  handled like a tank.
 I think the earlier  years the front rim  was narrower and  the later C10 years were wider
2.5 inches wide and the newer C10's are 3.0 inches wide- is that correct?
Offline CRocker
  • '02 C10 CDA # 416
I think you’re right!
Offline Bearcat
Here is a good link that explains it.
http://www.cog-online.org/clubportal/clubstatic.cfm?clubID=1328&pubmenuoptID=34855
Stock C10 Tire Sizes
The stock front tire for the 86-93 Concours is 110/80-18 and fits on a 2.5 inch wheel. The stock size front tire for the 94-06 Concours is 120/70-18 and fits on a 3.0 inch wheel. For both the stock rear tire is a 150/80-16 tire fit on a 3.5 inch wheel.
Fitment Observation
This article is about tire fitment observations for the 94-06 Concours using aftermarket 120/70-18 front tires. The stock Dunlop K700 series tires are radials tires, and the 120/70 front is designed for a 3.0 inch front wheel the Concours has. However this is somewhat unique. And the problem is no one really likes the stock tires very much. Many like to choose a more performance oriented tire. The problem with the performance oriented radial front tires available in the stock 120/70 size, is they are intended to be mounted on a 3.5 inch wheel. If you check the websites for Dunlop D205's, Avons and many other MFG's the 120/70 size is designed for 3.5 inch wheels, with 3.5 inches being the minimum width allowed and 3.75 or 4.0 being the widest.
The first thing I noticed about the Avon AM26 110/80-18   vs   the Shinko Verge 120/70-18 was the turn in.    The Shinko falls into the turn while the Avon is more progressive.
Offline Jim Snyder
  • COG#: 7055
I told you you'd like them. For all of the years folks said there were few options for stock size C-10 tires, and Avon had the AM-26's all these years.
Offline Bearcat
You are right, they are great,  They function well and have a nice looking tread pattern, Plus the price is reasonable,  Anyone with a C-10, in the market for tires should get a set of Avon AM26's.
