Author Topic: Mean Streak rear wheel/brake mod  (Read 1422 times)
Offline bikerhawk
  • COG#: 9207
« on: July 18, 2018, 04:50:42 pm »
Here's my version of the C10 Mean Streak 17" rear wheel conversion.  Credit to Yamahawk for the inspiration.  I had time to mock this up while waiting for a new driveshaft to arrive.
I had difficulty finding a machine shop with the equipment to machine the wheel, so I went with using the MS rear caliper, disc, and bracket.  I was able to take off the necessary material from the bracket myself.
I found an extra C10 brake stay with the plan of fabbing up a longer version to clock the caliper back, per Yamahawk's installation.  To my delight, I discovered that since I run a Givi saddlebag/Happy Trail rack setup, I had plenty of clearance to leave the caliper in the stock C10 location.  So all I had to do is cut off one ear of the stay, drill out the hole, and get a shorter M12 bolt (trimmed to approx. 22.5mm) to fasten stay to bracket.  The pic of the trimmed stay is at a bad angle & makes it look like it's touching the disc, but it's not...it's even with the inside of the bracket.
The brake line is a bit long since I had ordered one with the idea that I would have to clock the caliper back, but it still works.  The stock C10 line is a couple inches short.
The nice thing is I can throw the original C10 parts back on in no time at all, should I ever have to get rid of the bike.
Tom Hunt
Lawrence, KS - Kansas AAD - COG #9207, IBA #68392
1998 C10, 111k miles (mine)
1994 C10, 35k miles (SWMBO's)
2002 KL250 Super Sherpa
Offline Jim Snyder
  • COG#: 7055
Re: Mean Streak rear wheel/brake mod
« Reply #1 on: July 25, 2018, 12:48:55 am »
Are those Soupy's lowering links? Loved my MS wheel conversion. I end up powder coating both wheels when I got done with the 17" conversion front and rear.
Offline bikerhawk
  • COG#: 9207
« Reply #2 on: July 25, 2018, 04:37:10 am »
They are Soupy's. I love the adjustability, especially as I keep screwing with my suspension geometry/ride height/weight load. I had them a bit too low on my trip and was bottoming out once or twice. I adjusted them to sit higher with the lower MS wheel (170/60-17 Metzeler vs. 160/80-16 Dunlop Elite 3), but I went a bit too far.
Will adjust later when I go back & tweak the brakes. Still have air somewhere...the twin pot Tokico with 2 bleeders seems a bit tricky to get all the air out.
Tom Hunt
Offline batboy
  • COG#: 12983
« Reply #3 on: September 03, 2018, 11:47:14 pm »
Swapping in a Mean Streak 17" rear wheel will be my first mod (I got the wheel ordered and on the way). I've located a MS rear rotor, bolts, caliper, and mounting bracket (brake stay). I figured why put in a Mean Streak 17" wheel using the stock brake, plus going to the expense and hassle of finding a machine shop that will do the machining when you can use a bigger rotor and better dual piston caliper (without machining). I have studied TXfatboy's and Yamahawk's pioneer efforts into making the MS brake fit without machining the wheel. Another forum member made an adapter out of aluminum for the stay to relocate bolt holes. I was looking  for a simple way to do this and Bikerhawk wins the prize for least complicated. My main question for this method is this: worse case scenario is that the factory right side bag might rub, right? I think I'll try this route and then go from there. If the bag does rub, I'll figure out some way to mod the thing to make it work. I might as well get the rest of the MS brake parts ordered. Thanks for blazing a trail, Bikerhawk.
Offline batboy
  • COG#: 12983
« Reply #4 on: September 04, 2018, 12:30:00 am »
Well, LOL, I found another variation on this theme. Looks like JDM's method (see link) is another viable option.
http://forum.cog-online.org/concours-c10-zg1000-general-chat-and-tech/as-close-to-plug-n-play-as-you'll-get-for-a-17'-wheel/msg544216/#msg544216
« Reply #5 on: September 04, 2018, 02:25:12 pm »
Jim S will probably post soon.
He's been using a front caliper {from a C-10} on the rear of his bike for some time.
All that is necessary is to weld on a tap for mounting.
He did the mod for my bike. Works fine.
We both have 4 pot Tokico's on the front.
« Last Edit: September 04, 2018, 02:28:35 pm by connie_rider »
Offline batboy
  • COG#: 12983
« Reply #6 on: September 04, 2018, 04:18:18 pm »
I was notified the Mean Streak rear brake parts I ordered were shipped. The donor bike only had 5k miles. Currently, the plan is to use JMD's method of installing a MS rear wheel without machining. That seems to be the "cleanest" way to do it. It does require modding the brake stay and shortening the axle spacer.  Bikerhawk's method is the easiest, but I decided I didn't like grinding the stay ear off of one  side. I'm no engineer, but I figure this was designed like that for a good reason.
Hey Ted, on the early C-10 are there options to upgrade the front brakes without swapping in a different wheel? I might consider a 17" front wheel eventually. Can Tokico dual piston calipers be easily adapted? I suspect an adapter plate or mount is probably needed at the very least.
Last question: are good braided brake lines worth getting?  They look good and I'd always heard that they work way better than regular flex lines (because they won't balloon as much). Any idea how long the line needs to be for the MS rear brake? Maybe something like 20", 21", or 22" in length?
« Reply #7 on: September 04, 2018, 04:55:59 pm »
As your SC, there is a member (Pbfoot) in the Houston area that machine's the mean Streak wheels.
He has done several..
He and Jim S, can advise you about the MS Wheel.
Pretty EZ to add Tokico 4 pots to the later model C-10' front.
Some tried the 6 pot, but they feeling was the 4 pot was best.
I built my own brackets, (using a std size rotor) but this guy is currently selling one.
http://forum.cog-online.org/c-10-emporium/brake-upgrade-brackets/msg647603/#msg647603
  I am not sure if his adapter is for a std or larger Rotor.
  He can answer your questions.
Jim S originally built, and later bought adapters to install Radial design Tokico's.
The ease here is it is adaptable to either diameter Rotor by adding a spacer.
   I like the radial design as it's EZ to adapt for either size Rotor, but more expensive than buying this used one.
I did not extend my rear brake line with Connie Front Rotors on the rear.
I did go to braided lines.
  They are an improvement, but not a huge improvement.
     Yesterday I was looking at an old discussion about my brackets with photo's.
     In it is a list of Calipers and rotors that will fit the C-10.
http://forum.cog-online.org/concours-c10-zg1000-general-chat-and-tech/brake-brackets-for-2003-connie-anyone-interested/msg323653/#msg323653
Here again, Jim is a better help than I.
Here is a discussion including Jim's Radial set up.
http://forum.cog-online.org/tiressuspension-c10/brake-conversion-food-for-thought/msg437736/#msg437736
« Last Edit: September 04, 2018, 05:27:40 pm by connie_rider »
Offline batboy
  • COG#: 12983
« Reply #8 on: September 04, 2018, 09:10:25 pm »
Ted, thanks a bunch for all the info and links. Although, upon further refection, I think for now I'll just do the Mean Streak 17" rear wheel conversion and rear brake upgrade since I have the parts on the way. Perhaps I should ride the bike for a while and let it tell me what it needs next. The reason why the 17" rear wheel swap was first is because the rear tire is about toast and I didn't find diddley squat I wanted in the 16" wheel size.  I've settled on Michelin Pilot Road 3 for the front (120/70ZR-18) and Michelin Pilot Road 4 for the rear (170/60ZR-17).
« Last Edit: September 04, 2018, 09:17:57 pm by batboy »
Offline esmoojee
« Reply #9 on: September 05, 2018, 02:54:11 pm »
I have a zx6d rim and spacer for the front swap if you’re interested. It’s listed in the classifieds.
