Author Topic: So how do I start?  (Read 1396 times)
Offline Volcantour
  • Ride long and prosper
  • COG#: 8892
So how do I start?
« on: September 20, 2018, 12:59:12 am »
Have a '99 Connie with 90K+ miles on it. Ride is a bit ... rough. Has new Progressive springs with new fork oil (15W). No spacer as the length of the new springs matched that of the stock one.  Suspension improvement would make this a keeper. How do I start with the analysis and eventual improvement?
TCARS, y'all
COG #8892  CDA #0309  IBA #45302
1999 Concours, 2017 DL650 XT
SE AAD
Re: So how do I start?
« Reply #1 on: September 20, 2018, 08:56:49 am »
2013 Kawasaki Concours 14
Offline Jim Snyder
  • COG#: 7055
« Reply #2 on: September 20, 2018, 02:34:22 pm »
Depending on your riding style (aggressive or cruiser) will determine which way to go. Progressive springs are great for cruising but if you plan on doing any aggressive twisties the Sonic 1.1 or 1.2's would be more in order. As far as the rear changing the shock has several options. The ZZR 1200 shock as well as the C-14 are two of the most popular rear shock mods available for a reasonable price. Anyhow that will give you something to think about.
Offline Volcantour
  • COG#: 8892
« Reply #3 on: September 22, 2018, 03:09:00 am »
Much obliged. Now, for the thinking part..... :great:
TCARS, y'all
SE AAD
Offline SteveJ.
  • COG#: 5603
« Reply #4 on: September 22, 2018, 10:55:56 am »
Well...you do have plenty of thinking fluid.  :beerchug:
Tick Tock, baby (Ironbuttal)
Offline Ranger Jim
  • COG#: 6720
« Reply #5 on: September 22, 2018, 11:09:28 am »
I think you need to define "rough." Also what have you done?  Did you drain/replace the fork oil? Did you measure the level of the oil or simply add the "correct" volume?  Have you done anything to the rear shock (change the air pressure, get a rebuild kit from Murph, etc.)?
JIM CULP
Offline CaffeineMan
  • In the shadow of the Valley of Death
  • COG#: 7763
« Reply #6 on: September 22, 2018, 01:57:15 pm »
I enjoy my '01 C10 a whole lot more now that I've done this:
- Race Tech 1.0 fork springs (straight rate) - $130
- Race Tech gold valve cartridge emulators - $170
- Progressive 465 rear shock from Murph - $400
To set context:  I consider myself a medium-speed rider.  I'm not as fast or aggressive as Jim Snyder, but I'm not a pure cruising rider either.  To me, the tradeoffs are budget vs performance (riding style) vs shop time.  My parameters:  I'm not flush, but I'm not broke. I'm a medium rider, and although I do my own work generally, I'd rather be on the road than in the shop.  ;D
The Race Tech stuff I did is the middle ground between the cheapest/simplest option of replacing the springs/oil and the high-performance and involved option of replacing the entire front end.  Have to take the forks off to do it, but I also replaced the fork seals and added a fork oil drain plug at the same time.
The Progressive 465 probably has less performance than a C14 shock, but way more than the stock rear.  It was medium expensive but best of all it just bolted up!
All of this, together with new tires gave me great performance on my 3-week Three Sisters National trip this year!  No more front end dive under braking, no wallowing in the back. :great:
"You put antiseize on those, right?"
17 C-14 Candy Imperial Blue ("Baby Blue")
01 C-10 Sonic Blue ("Old Blue") - Decommissioned, in storage.
Offline Volcantour
  • COG#: 8892
« Reply #7 on: September 22, 2018, 04:48:20 pm »
The ride catches more road anomalies/bumps, bike sits lower on center stand for some strange reason (rear tire is not as high in the air), and it just feels like there is more effort needed to maneuver the bike.
More specifically the only changes made include: new Progressive springs with no spacer to increase tension, 15W oil measured by level of oil using Murph's equipment for such purposes, front shocks were rebuilt about five years ago by a knowledgeable fellow (i.e., not me), no changes to rear shock other than adding/subtracting air pressure and changing dampening from time to time.
TCARS, y'all
SE AAD
Offline Volcantour
  • COG#: 8892
« Reply #8 on: September 22, 2018, 04:49:37 pm »
Thanks!
TCARS, y'all
SE AAD
Offline Ranger Jim
  • COG#: 6720
« Reply #9 on: September 22, 2018, 07:18:20 pm »
You could try a lighter weight fork oil and rebuild the rear shock with Murph's kit (it's easy to do). Those are fairly inexpensive and easy to do. After that you could go to a C14 rear shock.
The rear not being as high off the ground is likely due to the front fork being more extended.  I suspect you have too much oil in the forks.
JIM CULP
Offline SteveJ.
  • COG#: 5603
« Reply #10 on: September 22, 2018, 07:24:28 pm »
Changing the rear shock oil made a bigger difference than one would think. Get Murphs' kit.
  • Stayin' for the people....
« Reply #11 on: September 23, 2018, 12:11:40 am »
Whaddya wanna spend Tom?
Iffin' you wanna go frugal, cut the factory springs, throw in a spacer, and
change the fork oil.  Then show the rear shock some love.
Wanna drop some coin, the straight rate springs and emulators will
vastly improve cornering confidence, and stop the nose dive.  This
works well with the factory rear shock in place... just rebuild it.
If you need some OEM springs to hack, you can have mine ('06).
Before swapping out the rear shock, I'd consider the 4 pot front brake upgrade.
Better brakes are a good thing, and with a bit of patience, can get a set on the cheap.
Good luck!
