Author Topic: Concours (C14) Fender Extenders Front and Rear  (Read 89769 times)
Offline DrBlackbird
Re: Concours (C14) Fender Extenders Front and Rear
« Reply #475 on: January 08, 2019, 01:26:24 am »
PM sent for a Set of extenders......
Offline Blue One
  • COG#: 12489
« Reply #476 on: January 12, 2019, 03:21:25 pm »
Thanks , your package is on the way.
Larry
Offline mirage
  • Walking stick
« Reply #477 on: February 05, 2019, 02:12:52 am »
Went for spirited ride (130 miles) and due to the weather being hot/cold the farmers had really tracked up the roads with what came off of their tires (you can't fault them they are trying to take care of their cattle).  I was really glad to have this addition on my fender since it bought a little piece of mind over dirty roads at speeds that were …...happy.
Dan
2004 ZRX
2006 KLR
2014 Concours
Offline Hexrays
  • COG#: 12889
« Reply #478 on: February 05, 2019, 02:37:24 am »
Good to hear. I have yet to install mine. Did you drill the fender or use some sort of adhesive, or both?
2014 C14, Risers, Cee Bailey Windshield, Givi Top case, GTR Ultra Series LED's, PIAA Sports Horns, Kuryakyn Passenger ISO Pegs.
Offline Blue One
  • COG#: 12489
« Reply #479 on: February 05, 2019, 05:53:46 pm »
With my front and rear extenders, follow the instructions and you'll be fine.
The front one is glued on using ABS glue, (the front extender is made from ABS plastic as is the Kawasaki front fender) the rear must be riveted on with the supplied black pop rivets as per instructions (the Kawasaki rear fender is Polypropylene plastic and the extender is ABS so they can't be glued well)
As they say if all else fails read the instructions  :)     :beerchug:
« Last Edit: February 22, 2019, 12:49:51 pm by Blue One »
