Good to hear. I have yet to install mine. Did you drill the fender or use some sort of adhesive, or both?
With my front and rear extenders, follow the instructions and you'll be fine.
The front one is glued on using ABS glue, (the front extender is made from ABS plastic as is the Kawasaki front fender) the rear must be riveted on with the supplied black pop rivets as per instructions (the Kawasaki rear fender is Polypropylene plastic and the extender is ABS so they can't be glued well)
As they say if all else fails read the instructions
