• *READ ME * READ ME * READ ME * READ ME * READ ME * READ ME* READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * If you are a current COG Member or Forum Subscriber and this is your first visit to our new site and forum, please go to www.concour.org and follow the instructions at the top of the page to activate your account and gain access to your site and forum.
  • READ ME * READ ME * READ ME * READ ME * READ ME * READ ME* READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * Can't post after logging to the forum for the first time... Try Again - If you can't post in the forum, sign out of both the membership site and the forum and log in again. Make sure your COG membership is active and your browser allow cookies. If you still can't post, contact the COG IT guy at IT@Concours.org.
  • FORUM NAME - If you are a COG member and your user name does not match your name in the old forum, you can request it to be changed. To request a name change, send an email to IT@Concours.org. Include in the email your COG member number, incorrect forum name and correct forum name. Your request will be processed in order of receipt and at volunteer speed.
AdMore Lighting Inc.
AdMore Lighting
Big Wheel
mattchewn said:
Question for you,
I just recently got a V47NT and also ordered your light kit for it. It doesn't seem to be any where near as bright as the kit I had on a different Givi case (V46NT I believe), a while back? Reasons? Just curious.
Hello Matt, the AdMore Light Kit for the GIVI V47 topcase should be about as bright as the AdMore Light Kit for the GIVI V46 topcase.  If it appears somewhat dimmer it could simply be because the lens surface is smaller on the V47 case as compared with the V46 case.  Assuming that you have your Light Kit installed as per the instructions and that it is operating in tail light and brake light modes, your light kit is operating properly.
877-564-8100
www.admorelighting.com
www.facebook.com/AdmoreLighting
AdMore Lighting
Big Wheel
connie_rider said:
Just ordered mine..
Thank you!!!
Fais said:
Received my order and the quality of the hardware and wiring is very impressive.
!!Can't wait to install!!
Thank you both for your orders. We hope you enjoy your AdMore LED kits and please ride safe!
connie_rider
[/quote]
I really hope that was an error as I only ordered 1?
Gypsy JR
Iron Butt
Thanks for offering the discount, very nice of you!
I don't mind that I purchased my 3rd set of AdMore LED lights for top cases 8 months ago and didn't get a discount. I'm happy just to have them installed doing their job.
connie_rider
AdMore;
(unless I am totally confused) There is an error in the (LED470-KAW-T-TS-LIGHT KIT)  installation instructions:
The instructions say  Green is Right side/yellow is Left side..
On my bike wiring (2014 C-14); green is on the LEFT side and I hooked it to your GREEN plug. (ie: green to GREEN)
                                                        There is not a yellow (nor green) wire on the right side on my bike.
                                                            (Don't recall the color, but it was not yellow or green).
                                                          I hooked the Right side to your Yellow plug. (ie: ?? to YELLOW)
I followed thru from there (with Green on left and yellow on right) and all worked out fine...
VERY IMPRESSIVE LIGHTS!!!!
AdMore Lighting
Big Wheel
connie_rider said:
AdMore;
Hi Ted,
Thanks for your post. You may be a little confused (not totally but just a little!).  The AdMore C14 adapter that you bought with your AdMore Light Kit comes with the following instructions:
"Unplug the three (3) OEM connectors and connect the AdMore PH-KAW1 Plug-n-Play Adapter (Green = Right, Yellow = Left)."
The green and yellow wire colors are in reference to the adapter connector colors (not your bike wire colors).  So, the green connector on the AdMore adapter should be connected to your C14's right side OEM connector and the yellow connector on the AdMore adapter should be connected to your C14's left OEM connector.
The fact that your light kit is operating correctly with the green connector on the left and the yellow connector on the right is interesting but as long as your AdMore lights flash with your respective right and left OEM turn signals, you're all good!  Glad to hear that you are pleased with the final outcome!
connie_rider
Ahhhh sooooooooooooooooooo...................
snoofus
Tricycle
I installed the AdMore Lighting rear light bar on my 2008 Concours. I've had many comments about how visible it is - and their latest product is apparently brighter.
AdMore offers a harness for the Kawasaki so you don't need to tap into the wiring harness. Although products like PosiTap are a huge improvement, I'm still wary of anything that cuts into the insulation of the wiring original wiring harness.
The AdMore harness clips into the existing connection for the brake and turn signals. This makes for a very clean installation and was a deciding feature in my decision to purchase this product over others.
http://admorelighting.com/store/index.php?route=product/product&product_id=137
zg
Can you post some pics Rob?  ???
connie_rider
I wanted to ping this discussion. I have the AdMore lights on my C-14.
VERY IMPRESSED by them. These are FAR better than the lights that Givi sells...
Recommend them to everyone.
The discussion prior to this note was about a sell they had last year.
Perhaps with enough interest, Tom will do another?
DialedN_13
Bicycle
connie_rider said:
...The discussion prior to the note was about a sell they had last year. perhaps with enough interest, Tom will do another?...
Showing interest...possibly for an E55 AND a V47
