AIRING UP ZG 1000 SHOCK
How do you air your shock up on your ZG 1000. Do you use a bike pump, Do you use your air compressor, I have a JACO Flowpro, tire inflation guage. It is very precise and great to use on my motorcycle tires. It has a built it bleeder valve. It has a built in guage ) 0 to 100 that is very accurate. But my question is. What is safe to use and what do you use.
Initially upon getting my C-10 I used a bicycle hand-pump, afraid of over-pressurizing, etc.
Then after a connector on the bicycle pump broke I used my small 12V tire pump and just tapped the air, sometimes took a few times as I was always afraid of over-pressuring, never did.
Wayne, Carol & Blue
Believe it or not, the best way is to use an air compressor. <S__t starter grin> šŸ˜œ
(Waiting for the OMGawds's and Arghhhs to stop, and the "you're going to over pressure it" comments to fade away).
Step 1; Buy a pressure regulator with gage.
Step 2: Install the pressure regulator into the air line.
Step 3: Put an air chuck at the end of the hose.
Step 4: Set the pressure at the desired pressure you want, plus 5 lbs. (ie; If you want 40, set reg at 45 / etc)
Step 5; Put air into the shock thru the shock fill port until all air flow stops.
Step 6: ""Rapidly"" remove air chuck from the shock fill port.
Step 7: Put everything up and go for a ride.
* The reason this works; The regulator assures that you "cannot" put too much pressure in and you "can" set the Reg. for whatever pressure you want.
** The reason you set it at 5 psi over your desired pressure; When you remove the chuck from the shock fill port you "will lose" about 5 psi from the shock. (Some experimentation will be required)
Let the FLAMES begin...
Ted I do it the same way. My compressor has a regulator on it already. If you use a screw on fitting you will lose all the air while you take it off. I set it for 45 and ride 2 up with gear.
I've done this too , but it's nice to carry the little shock pump in the bags or tankbag on trips . I like to be able to increase or decrease pressure when removing my gear at the hotel or campsite and riding lighter , but I pack pretty heavy on trips .
I built mine as a remote "Regulator/air chuck/tool" with a quick disconnect.
The tool attaches at the end of the air hose. (Can take it with me if I want)
I did this so I could look at the pressure gage. (To see/know I had set it, and adjust if needed)
I agree on NOT using a threaded air chuck. (loses too much air when you disconnect)
I didn't take an air pump on the road. I kept mine at around 45-50 psi as I liked the stiffness for playing in the twisties.
(I've now replaced the rear shock with a C-14 shock).
Back in the day wen I had my 86, as many of you recall those had front forks that were pressurized from 3 to 7 psi.
Most bike shops back then sold a small syringe that you could air up the forks and the rear shock as well. They were only $12 bucks from what I remember. Now they come with gauges on them an sell for around $50.
I had to replace the back shock on my 2005 with a progressive so I don't use them anymore, have them around somewhere though.
