I will be installing auxiliary lighting mounted from the underside of my side view mirrors. I am wondering how people have routed the wiring for a flush professional look.
That is exactly what I was contemplating. Did you cut the factory connector off, run the wiring and re-attache the plug/wiring on the other side? My only concern was the ability to warranty my lights if I cut into factory wiring.
The factory plug is about 1/2" in diameter and I don't want to cut such a big hole.
Pretty certain I did...if ur worried about cutting the factory connector off, u could probably drill the whole to that size and use a grommet to seal the hole nd wires..
