You must have an active membership plan
Use the bottons upper right to Log in or Register for membership - or click here to register to join COG
All new registrations are completed and authenticated using the club's main webpage.
Been away from the forum...yep you should have gotten a tube of both, I can send them on or you can pick them up local and i'll refund you $12 which ever works best for you,,,
