Can't post after logging to the forum for the first time... Try Again - If you can't post in the forum, sign out of both the membership site and the forum and log in again. Make sure your COG membership is active and your browser allow cookies. If you still can't post, contact the COG IT guy at IT@Concours.org.
IF YOU GET 404 ERROR: This may be due to using a link in a post from prior to the web migration. Content was brought over from the old forum as is, but the links may be in error. If the link contains "cog-online.org" it is an old link and will not work.
GP does indeed make a cartridge kit in addition to a re-valve kit. One note though if you go this route which was advised of me from my susp guy, you'll need risers.
Thanks for posting this. Those cartridges look very, very interesting and I will probably have to try these out.
I've had the Traxxion cartridges for many years and have always been pleased, but when running hard even on the street, I have to turn both compression and rebound all the way in, and then out about a half click. It makes for a harsh ride but works ok.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
