I finally found a local o-ring dealer that matched up the two coupler o-rings and so I got two new o-rings for the coupler as suggested. One goes on the driveshaft and one goes on the pinon gear shaft.
I also measured out exactly 225mL of gear oil to put in. Service manual says capacity is 220mL but I figured I'd lose 5mL between what stayed in the beaker and the funnel as it all doesn't drain out of the beaker or the funnel. 220mL does NOT come up to the bottom of the threads with the C10 on the center stand. about 1/2" below. approximately.
Perhaps if the bike was on the kickstand and not the center stand 220mL would be full to the bottom of the threads?
anyway, went on a 430 mile jaunt today to test it out and yeah! no more final drive leaks. Not sure if was the coupler o-rings or only putting 220mL of gear oil in the final drive. or maybe both.
And guess what was in my email inbox when I got back today. An email from the local Kawi dealer telling me that those 2 o-rings I ordered back at the beginning of the summer finally came in.... go figure.....
-tdbru
-tdbru
