WOULD YOU LIKE TO BE ABLE TO POST AND ACCESS MEMBER ONLY CONTENT AND FEATURES Join / Upgrade / Renew your membership to enjoy full membership and posting privileges. For simple instructions, click here
Need thoughts on adding fork brace after lowering Connie. Front was only lowered about a quarter of an inch. Anyone who has added fork brace has it noticeably inproved ride and handling. Thx in advance
If your not an aggressive rider, you will not notice the difference.
If you are an aggressive rider, it will feel a bit more stable/planted in the turns.
NOTE: If you buy one, you "must" buy one that is made to fit the year of your bike.
If you have a used/deal somewhere, do it. Doesn't hurt.
But, I don't think you would notice much difference.
If you want to do it, and get the best, contact Murph.
To do it right you should fit the brace to the forks. Before you start check if you have an striction.
Bounce the front end up and down a few times, note where the forks settle on the upper fork tubes.
You would like it to stop at the same height each time. Then add the fork brace and bounce again.
Once again you would like it to stop at the same height or close to the same height. If not the
brace needs shimming on ether the inside of the brace or outside of the brace cap.
Tube tops and/or brace are not perfectly round at contact points. Figuring where to shim is problematic.
Instructions are simple. Application is not however. That was on a KB brace made for the early model application.
My brace was too tight at one spot and needed to be have tube top relieved via sandpaper.
I took mine off and went for a ride just to see if it was different . I noticed the difference . Didn't feel bad but definately different . My bike is an 87 and I hear the early model braces are hard to find now .
