View attachment 29879this is what I found in the right fork tube. Totally damaged thread. I think it's better to not open the cap, until I have new fork tubes.
Riding with 28mm sag is not that bad.
Thank's again for your help Connie Rider and Mercer
I just saw this discussion again. Not sure why I missed it when you posted the spacer installation. (June)
(Prolly while I was at the National??)
Looking at the photo, it appears to me that someone removed a damaged fork cap from the tube.
They probably drove a screwdriver (or other) into the tube to remove the cap.
NOTE: The damaged threads are NOT a concern as their strength is fine.
The only concern {from that repair} is the damaged
seal area.
ie; I think I see corrosion pits in the sealing area of your fork tube. (??)
If so, the damaged seal area of the fork tube "may" be the answer to why a 25 mm spacer changed the sag by 32 mm.
Explanation;
The air in the fork is compressed when the fork moves down.
That compressed air acts as a spring.
If the o'ring was not sealing (??), the air was not compressed.
With that lack of compressed air, the sag would be greater.
If it is now sealing, the sag will be decreased.
Additionally, "did you change the level of the oil in your forks"?
Was it extremely low when you disassembled the forks?
If you raised the oil level from what it was,
the air would compress more, (because the air space is smaller).
If so, that change could have also effected the sag slightly. (decreased it)
By the way, the damaged area in your tube may explain why your caps are not stock.
They may have machined special caps that moved the o'ring location to a different area. (to ensure a seal)
If so, I salute the person that was able to do that repair. Fine craftsmanship!
