For those who have removed your front forks on a '99 or similar, can it be done while on the center-stand and jacked back (tipped) onto the rear wheel, or does the front have to be even higher than that?
Also, I'm a bit confused on a couple items if I only want to change the oil...
How much disassembly of fairings is needed to get forks off (other than front wheel and fender)?
How do you know how much oil to put back in (Clymer kind of baffled me)?
Or should I just invest in a vacuum pump and suck out all the old oil without pulling the forks (but the refill question remains)?
Ready? GO!
TIA,
Scott
Ready? GO!
TIA,
Scott
