Helmet lock options?
Rushfan Greg
Guest
Guest
Hey all! Just wondering what the helmet lock options are for my 09. My first Connie had a Givi top case that had an add-on helmet lock that bolted on the bottom. My current 09 has a Kawi top case. Are there any options for this case?
Thanks in advance,
Rf G
nothing will prevent theft, if the perp is determined, and has tools, but most easily swayed from "walk by" thefts, can be cotrolled with a cheapo gun lock cable device..
going bigger and stronger, in cable and lock size, allows you to also string the cable thru you jacket/pants/gear, and provide a manner of security that will still draw attention to the thief, and slow them down...  :great:
Pretty certain, unless u have pictures of ur old case with the locks, that the locks were NOT attached to the case but instead to the rack the case was attached to.  AST makes a set of bolt on helmet locks that are keyed alike.  Ryan from AST a video of installing them on you tube.
According to AST’s website, the pair of helmet locks are no longer keyed alike.  The manufacturer of the lock no longer offers this option.
Ah, yeah...This is a great idea (I'm glad I thought of it  ;D). Seriously though, Good idea.
You're correct. It was added to the rack the case was on.
The link I posted states they're not keyed alike.
Victor Salisbury said:
Helmet Guardian locks are another option. Been running these for 10+ years.
https://www.advdesigns.com/heguprheselo.html?gclid=Cj0KCQjw6575BRCQARIsAMp-ksOVSjB-p64hn40ZYgEV7UN-dEuF1xArALsiWQXbrxGe4KfUyUAb99oaApzhEALw_wcB
BTW, there is a DIY way to modify the locks to work with an existing key. A process I learned from here to modify a GIVI lock to work with the my C10 ignition key.
I'd like to know that one. My Givi keys are junk thanks to the plastic head coming apart.
It takes disassembling of the GIVI latch to get to the lock cylinder, I remember for my E52, getting the latch assembly out was a little tedious. Not sure about other models.
However, high level, once you have the lock assembly out over a nice,quiet, no heavy winds, above white towel or other clean surface, carefully remove the cylinder. The 'wafers' are spring loaded but with the key in aint going no where. Then, carefully remove the 'stock key', (watch those spring loaded wafers)  place the key you want to work in the lock cylinder. You'll notice some or all the wafers will be sticking up above the lock cylinder barrel different amounts. You want those wafers to end up flush.  I used my dremel tool with a sanding drum, sanded down the wafers until they were all flush.  Once all the wafers are flush with your 'other' key, it will work for that lock. And the original key will still work.
(I have been known to remove the key, pull the wafer(s) (one at a time) and holding the wafer with a very good pair of pliers, lightly grind down the wafer top with a bench grinder. But you gotta be careful, slow, steady hands.)
One advantage we found with the GIVI lock 'conversion', when you used the ignition key to unlock the latch, you could remove the key from the latch leaving it in the 'unlocked status'. That way you could open/close the lid latch with out having to have the key in the lock, a minor side benefit.
HTH
