Kind of a long story. I was filling up gas in eureka, Mt. Three other dignified riders pulled in, one on an old cbx 6 cylinder. I was visiting with the guys and they were going up to Yaak also. Let's stop to take some pictures and they passed me. Later on on the Yaak road I came around the corner and caught the side of a large hole in the road. Just a little ways up one of the guys was pulled over on his Indian. He had bent and cracked his rim. So I run his buddies down and we all came back. As we are coming back I noticed that my rear tire was a little low.
So I put it up on the center stand and found a small wire. Pulled out my plug kit and plugged it and it still had 35 lb of air. So then I hooked my pump up and it didn't work. I figured it was a switch but I didn't have a small enough screwdriver to take it apart so I ended up smashing it apart and then putting it back together after I bypass switch but I couldn't hold it together properly by then I was down to 20 lb of air.
One of the guys rolled that flat tire in Indian 25 miles back to town. He had it moving pretty good because they left me in the dirt. I was only traveling 45 miles an hour cuz I didn't want to heat the tires too much. After I got air I did finish up the Yaak ride.
The thinking though, about some of the places I ride by myself. Also got me thinking that I need a new pump
