It's front brake time. Just started to hear squeaking noise coming from the front brakes as the lever is squeezed coming to a stop.. Did a quick check of the pads and noticed the inner pad on the right side has an uneven wear area on the lower end. Further checking revealed the upper piston is not moving. Got (2) caliper rebuild kits, speed bleeders and banjo bolt washers on the way from Murphs.
