HaHa! It is a wood grain felt padded table protector about 1/4 inch thick. I had a white painters tarp in place but it did not have any contrast for the white pipe. My wife would surely object otherwise.Ok I have to post what most of us are probably thinking.
By the looks of your pix, you either live alone or the misses was away when you took the pix of your setup on the dining room table, especially without a towel or cardboard protecting the table, lol. Even with the table protected I would of probably got the "WHAT THE HE\\ IS THAT THING DOING ON MY TABLE", notce the comment are all in caps.
Thanks for posting your jig setup.
Yep, I went with maw kaw needles after having a # 4 stick. But needle springs seem to not like alcohol in gas do think. Now that I use fuel treatments and TW3 oil mix to tank fills problems like that are nil.Thanks for the kind words. I tried to sell the design to NASA, but it turns out they don't use carburetors. Who'd thought? Maybe we should just switch to solid rocket boosters............
One thing I found out by being scrupulous about setting the FUEL level as opposed to just the float height.....The first time I went through my carbs I used after market float needles and the spring rates were not consistent. This allowed the actual fuel levels to vary a lot from one carb to another even though the float levels were the same. I solved the problem by getting Jen-you-whine Keihin needles from Murph.
Here's pic showing the how my setup will tilt any direction.
My fiance doesn't even like it when I eat at the dining room table, she'd prefer I eat and sleep out in the garage.
Ha! My wife wants all her tires like that! She thinks they put that feature on the dash so one would know and fix it. Except her idea of "fix it" is to park the car in front of shop and tell me as she walks in from her work commute.Being an old aircraft mechanic I've always wanted to put a 4-cylinder EGT system on my Connie, but yeah it's a little spendy. The big downside is it will never read what you expect it to and you'll spend the rest of your life ****ing around with your engine trying to "fix" something that isn't wrong. I've had airplane owners get really really mad because all of the cylinders on their engines aren't within 2 degrees of each other. Well......they aren't and won't ever be.
Alcor By Tempest Basic EGT Systems | Aircraft Spruce
Alcor By Tempest Basic EGT Systems Alcor EGT gauges are aircraft quality gauges which will provide precise monitoring of engine temperatures. PMA/FAA approved.www.aircraftspruce.com
Oh unrelated perhaps, I get my fuel line from Aircraft Spruce.
Tygon Lp-1200 Fuel Line Tubing | Aircraft Spruce
Tygon Lp-1200 Fuel Line Tubing Clear, high-performance fuel tubing for small engines.www.aircraftspruce.com
