- COG#
- 14343
I've searched the archives here the best I can as well as Youtube. I think I've found a simple way to remove both wheels one at a time, but what's a safe way to remove both? What I'm thinking is to get it up on the center stand with a 2x6 beneath the stand, secure the center stand somehow to the frame so it doesn't move. 1st. My plan was to use a small jack with a piece of wood under the engine, jack it up some, raise the front end and remove the front wheel. My thought was to put a thick moving blanket under the front forks and lower it down, then move onto the rear.
Anyone have any suggestions to improve this plan? My only past experience doing this was on my dual sport, and it was pretty easy using a motorcycle scissor lift centered under the bike to raise the entire bike off the ground. I doubt that jack can be centered well on this bike or handle the weight. It says it will handle 1500lbs, but I'd sure hate for the bike to fall.
