After having burned out both low beams, I bought a couple of standard H4 LED replacement light bulbs. ( See them here -> https://a.co/d/0NvEwj9 ) After the quick and simple install which went without a problem, upon testing and aligning them, I find that the low beams are OK but the high beams lack any focus or "direction"... Meaning unlike the original bulbs which cast their lighting in a mostly rectangular manner in the are one would want it, these bulbs are OK in low beam and are seemingly directional in a similar manner, but the high beams lack any kind of focus and are thus casting light in most all forward directions with out a concentration of light in the area one would want it. And thus it does very little to boost the visibility of the lights over what is visible from the low beams. Has anyone had this experience? Should I try the more expensive "pathfinder" lights? Could I have not seated the bulbs such that they use the light reflection mirrors in the light bay to correctly to give a forward focus in the same manner that the OEM lights did? I think these will be fine for low beams, day riding but the expected hi beam lighting from them leaves MUCH to be desired....
Any suggestions, experience or advise is appreciated..
