• Forum Subscribers and COG Members, please be aware of policy changes put into effect due to action of the COG board of directors based on input from members. The new membership system makes it possible to implement these changes.
    Forum Subscribers – Forum Subscribers get a six-month limited feature trial forum membership. Forum Subscribers Read the Details Here.
    Members – Your full forum access is only in effect while your membership status is active. Members Read the Details Here
  • FORUM NAME - If you are a COG Member and your user name does not match your name in the old forum or you just want a new one, you can now change it on your own. Read the Details Here
  • *READ ME * READ ME * READ ME * READ ME * READ ME * READ ME* READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * If you are a current COG Member or Forum Subscriber and this is your first visit to our new site and forum, please go to www.concour.org and follow the instructions at the top of the page to activate your account and gain access to your site and forum.
  • READ ME * READ ME * READ ME * READ ME * READ ME * READ ME* READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * READ ME * Can't post after logging to the forum for the first time... Try Again - If you can't post in the forum, sign out of both the membership site and the forum and log in again. Make sure your COG membership is active and your browser allow cookies. If you still can't post, contact the COG IT guy at IT@Concours.org.
Signature Line Rules & Creation
ForumAdmin
Administrator
Staff member
Rules
All signatures should not exceed the following size limits.    4 lines normal size, 8 lines small size and up to 90 chars per line. (Blank lines count as lines.)    For images in signatures: 1 image up to 300 pixels wide, 125 pixels tall and 20k in size    Duplicate links to the same URL in a signature are not allowed.
How To
Create a custom signature block:
First navigate to your profile: Profile > Forum Profile
There you will find the Signature section where you can add text and images to your profile.
You are able to add formatting tags similar to HTML to highlight or bold your text etc and add a link to an image image hosted elsewhere on the web. For example the code in a signature block can  look like this:
Code:
[b]Fred Blogs[/b]
[i]Bottle Washing Officer[/i]
AMA# 1082227
ROK# 20033345
[URL=http://rides.webshots.com/photo/2447706780100596652fCpIlv][IMG]http://thumb12.webshots.net/t/75/75/7/6/78/2447706780100596652fCpIlv_th.jpg[/IMG][/URL]
The b and /b in the square brackets says the text inside the brackets/braces is to be bold,
the i and /i is to italicize the text.
The text/code for the image and link was taken straight from my Webshots account.
To copy the code above select the "select" link above and copy to your clip board and paste it into note pad or whatever to edit it with your own text and image link and then copy that to the signature section in your profile
It looks like this:
Fred Blogs
[font=verdana, arial, helvetica, sans-serif]AMA# 1082227  [/font]
[font=verdana, arial, helvetica, sans-serif]ROK# 2003345[/font]
Dear Forum-Admin:
Is using a Webshots type of service  common practice due to storage limitations on the COG site?
I already have way too many Internet accounts, and I'm trying to simplify my digital existence:)
Cheers,
Simon
colinp386
Crotch Rocket
Good question.
Truth is that that info was originally posted up for the original forum that did not support server-side images.
This one (Simple Machines) does so you can use them.
it's not so much an issue of space as performance. The more files that are stored on the server the slower it will get . However that's not an issue at the moment, and probably never will be.
Bottom line is if you want to use the server store go ahead, but note there is a size limit.
Cheers
Colin
Colin:
Thanks for the info. I'll give that a try. My "visited maps" are only 5KB each, so they shouldn't present any problem to the COG server.
Cheers,
Simon
S Smith
COG Northeast Area Director
Shaft-Drive said:
Colin:
Cheers,
Simon
IIRC, pics in sigs must be linked images.
S Smith
Simon...  does your tag line look like what you want now?  (the size is dictated by Photobucket's thumbnail size) The URL used was not correct.  View your profile to see what the code looks like now.  This is easily creatable by using getting the link from Photobucket's "share" button, click on the "Get Link Code tab" and then copy the entire code text for  "IMG for bulletin boards & forums -> clickable thumbnail"
BTW - pasted code in the post is treated the same as in the sig line.... the forum code will try to interpret & display it.
Hope this helps.
Jim217
Bicycle
I don't think I added the tag, Big Wheels, on my signature and I can't seem to find out how to delete it. Can you help?
S Smith
That field is a humorous ranking field based on post counts and can not be removed.  More posts graduate user up the riding scale. Look at others rank titles to see the different ones.
Hope this helps.
Steve:
Okay, now the map shows up. And I did nothing in the meantime (during my 6-week coffee break from the Forum:).
I'll read your suggestions again, Steve, when my brain's working a little better.
As always, thanks.
Simon
S Smith
Hope this helps.
Steve:
As always, thanks.
Simon
Simon - we fixed the typo in your sig line for you.
