Question, anyone find any difficulty getting the center protector to stick?
Reviews indicate several have issues with it not sticking/pealing up. I imagine at little heat during application would help?
No issues with the center pad to stick but the left side I did. Seemed I didn't clean the tank on that side properly when I overfilled and gas had dripped on that side. Once I cleaned it up with a dry rag then alcohol wipe no issues. But yea heat might help.
