Ya'll hang on a minute.
My swollen head makes it hard to get my helmet off..
Ron, now that you've used the turnbuckles, it will be easier to work out the Toy-hauler installation.
Secret Trick; On your Harbor Freight Chock; I discovered a trick.
I don't normally tell folks but (since you talked nice about me) I'll tell you.
I removed the bolt that the rocker pivots on, and moved the Rocker to a better {more forward} location.
To find the ideal position, I used an old tire, placed it in the Chock, and moved the {unbolted} rocker forward until the tire is slightly suspended.
NOTE; Keep the rocker location
as low as possible. (to ease loading}
I then drilled a new hole at the new rocker position and re-installed the bolt.
,,,{If you have the location exactly right, the weight of the bike will push the tire down until the tire barely touches the floor}
After the mod; {Because the bike is slightly suspended} the rocker will clamp the tire tighter and the bike will be more secure.
(shhhhh; Don't tell Marty I sed this)
