After reading some of the horror stories with the lower bolts I was a bit apprehensive. With a good dose of PB blaster, a lot of tapping and a prayer 3 came off. That fourth one was a scary one though! Now to ship front and rear off for springs and rebuild.
That upper right one when facing the bike was a major disaster for me. I eventually got it out but it was a PITA. Are you doing anything special to your forks?
Sending to DMr Performance suspension for springs and revalve. Needed seals so I decided to save myself some work and splurge a little! Sent rear shop in for same. Another member liked there work so I am trying it out.
