I usually ride with headphones in. When I got back, I noticed that my front brakes seemed to be grinding and slightly pulling to the left when getting on the brakes.
I just replaced the pads, and I just took the calipers off, and the pads are fine. I put them back on, and now it seems a bit better.
I still get a grinding and pulling sensation when braking while turning. I thought it was the floating rotors, but it sounds louder than that. There's no shimmy in the braking, just that weird grinding sound.
Ideas?
I think I found the problem; I installed a lightbar that I got from a member on here. Mounts to the bike using the fairing bolts that are above the coolant reservoir cover (not the ones holding it, but the ones above it). And when I brake, the bar is rubbing on the fender extender that I have installed. Looks like I'll have to mill some millimeters off the mount points to get it closer to the bike. Or relocate it somewhere else... That, and rebuild my forks for my weight.
I think I'm good. If a mod wants to delete this, please feel free.
Thanks!
-x01660
