I'm having a difficult problem with my 09 C14. There is a lot going on. When I turn the key it does the self check running the lights and sweeping the needles as it's always done, but now after that's done, the turn signal lights all stay on dim and the high beam light comes on on the instrument cluster. When I start the bike it runs but the headlights do not come on high or low beam and the high beam light on the dash may or may not come on. The turn signals stay on dim but will flash with the switch on side but the other side stays on diim at the same time. There are no messages on the dash and the red warning light is not on. When I switch the bike off the self test runs (lights and needles sweep) but it runs repeatedly, 9 times to be exact. I imagine that's how many times it can run within the 5 second time delay before power is shut down. I can't find anything on why it would repeat like that or what it may be trying to tell me. Local dealers are talking 3-4 weeks to get it in to look at it. When I try to explain what's going on they say they've never heard of anything like that happening before, which doesn't fill me with confidence leaving the bike with them to diagnose it. Not to mention the "diagnostic fee $$$$" I've tried testing the relays, swithces and diodes as described in the service manual, individually everything tests OK, put it back together and no joy. The first time the repeated answer back happened was after I got a punctured rear tire on a ride and the tire pressure got down to 18 psi by the time I got to a station with air, by that time the red warning lite on the dash was on too. It did it then when I shut it off. I plugged the tire, aired it up and rode it twice after that without issue everything normal. Any assistance will be greatly appreciated.
Bud
Bud
