I WANTED TO RIDE THE CONCOURS TO WORK TO DAY SO I WENT TO MOVE THE KLR AND OOPS IT TIP OVER NOW THE CONCOURS HAS SUM MISSING PLASTIC WERE THE HANDLE BAR OF THE KLR LANDED. SO I THINK IT COUNTS AS A CDA MOMENT
Which went over - the KLR or the Concours?
CDA's are for Connies only.
Still - kinda sucks that that happened.
Knock the Connie over and I'll get you your CDA!
