What do you mean '10 volt draw'... are you saying the battery is charged to a certain voltage and it drops to 10 volts when connected? Or, did you mean a 10 amp draw? Could be the ignition switch, or any of a number of things... you need to do some basic trouble shooting, like, unplug the ignition switch to see if the draw goes away...
Try unplugging the alternator, (and/ or the regulator if you can unplug it separately), remove fuses, etc... Any aftermarket wiring, lights, etc.?
Look the wiring over carefully for any spot that is worn through, melted, etc. Anything that can be unplugged, unplug it and see if the short goes away.
Had a faulty amp meter that was showing 10 amp draw. Tried 2 different meters and showing 2. 35. Still having found the source of 2.35 drain. What is normal amp draw?
I have checked over wiring. Can't find any worn or bare wires. Have unplugged all plugs I can find underneath gas tank, removed fuse, checked aftermath wiring, and not found drain. Put new battery in recently. Not sure if drain was happening before change of battery. Old battery was about 5 yrs old.
Thanks for any ideas.
Unless you have something like a clock that is on all the time, there should be virtually no draw. Certainly not a couple of amps. Even with a clock, it should be in the milliamp range, not amps. Are you sure the meter is not set up reading milliamps? How long before the battery dies, like, overnight, or are we talking weeks?
