I went for about an hour ride in 80 degree temp and when I got home the cooling fans were on when I parked in the garage and the gauge was at 3 bars so I just shut off the bike. About an hour later I returned to the garage and there was coolant running into the floor drain. I pulled off the left side plastic and found the overflow tank empty and overflow hose damp.
No leaks found so I am assuming heat soaked engine caused the coolant to expand to the point it flowed out of overflow tube. I am surprised that there is no logic in ECU to turn the cooling fans on after the ignition is shut off if it reaches a high temp. Does anyone have any experience with this issue?
