jaxrider
Scooter
I'm helping a friend with this bike, and it was not charging. He had one melted wire under the seat, one of the wires from his stator. The stator test out with an ohm meter, with 2 legs good and one shorted. I tested the regulator/rectifier by the Honda manual but it showed ok. We replaced the stator which is surprisingly more of a hassle than any Suzuki or Kawasaki I've worked on before. The bike showed 14v charge off idle and everything was great for about a week, then his battery started going bad. He had an independent shop look at it and they said it was the rectifier/regulator. He got one and installed it himself with no improvement. I am looking at it tonight and will perform the same checks I have done before. Is there anything else I can check? He had the battery tested and it showed good. thanks David David in Jax, FL COG# 7898 CDA # 2002 ZZR-1200 "Magic Carpet" 2004 Suzuki Intruder 1500 LC "Luxury Couch"
