Although the Concours14 and ZX14 are very similar bikes. They do have differences. We know that the C14 has front and rear accessory leads. But does they ZX14? Probably the best person to ask would be Privateer . He owns and rides a nicely modified ZX14. I'm sure he will know if know one else comes along first, to answer your question.
Some put the sockets in the ram air covers near the instrument cluster. Not a big fan of that, you have to solder in a quick disconnect or the cover will have to dangle everytime you want to remove the cowling.
Here is what I did. It has 2x BMW sockets, each heat controlled by a Kustom Komfort variable controller, plus a variable for my grips. My machinist friend could always make another. It mounts with a ram mount in the steering stem.
Most of the wires in the picture are gone now, I was experimenting with speakers, which I didn't like.
Pictures of my ZX14 in post below, ZX14 Super-Concours Express
It will be at the National sometime Monday morning, August 8th.
