Yes, those are old style TPMS sensors.OK you guys just talked me into replacing the TPM batteries---I'm pretty sure my 2012 Connie has the older version sensors -----after the tires are off are there any "tricks" to replacing batteries?View attachment 32770
I used these and they worked well. You do need to bend the tabs, but that is easy.
CR-2032/VCN Panasonic - BSG | Battery Products | DigiKey
Order today, ships today. CR-2032/VCN – Coin, 20.0mm Lithium Manganese Dioxide 3 V Battery Non-Rechargeable (Primary) from Panasonic - BSG. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.com
Sorry, about the three quotes, I cannot get the link to show any battery availability from there. Maybe a change in stock. In any case, the Canadian site does not seem to handle any batts.I used these and they worked well. You do need to bend the tabs, but that is easy.
Be careful buying batteries like these on Amazon. I've had "stale" ones more than once. That's why I like DigiKey, they are a Panasonic distributor and they are "fresh" from them.Batterys finally sourced on Amazon. Reasonably priced. Thanks again for the help.
