I bought a used 2003 Connie, the seller wasn't sure how many miles were on the engine because he went down and slid uder a truck with a hitch & cracked the engine. His dad is an airplane mechanic & he found a used 1000 Ninja engine & together they swapped out the engine. When I took it for a ride it ran great. I had it about a week then the problem started. It runs fine until approx 3500 RPM, then it bogs down & spits & sputters & shutters & will not accelerate any further. At idle it revs fine. The man I bought it from had the carbs cleaned in Feburary. I drained the bowls & no crud came out & the gas smelled fresh, inside the tank looks good, no rust. The spark plus wires were corroded so I replaced the wires & caps (Murphskits has a good set) & plugs, no change. I suspect the carbs even if they were done recently.I have freah gas in the tank & some Seafoam to see if this may help, haven't even burned a whole tank yet, don't want to get too far from home. Should I give it more time or consider pulling & cleaning the carbs again? The man who sold it bought a new Concours 14 & needed the room.
