Can't post after logging to the forum for the first time... Try Again - If you can't post in the forum, sign out of both the membership site and the forum and log in again. Make sure your COG membership is active and your browser allow cookies. If you still can't post, contact the COG IT guy at IT@Concours.org.
IF YOU GET 404 ERROR: This may be due to using a link in a post from prior to the web migration. Content was brought over from the old forum as is, but the links may be in error. If the link contains "cog-online.org" it is an old link and will not work.
I went with Galfer stainless lines this spring. Can’t recall where I found the best price. They come in many colors and added a huge amount in feel. Most times, I just use one finger on the front brake as it is so precise and powerful now. The install is easy with only the clutch line being a bit tricky. There is not much space to get the old one fished out; however, with patience it works. Rubber grommets from the hardware store reduced the space within the stock guides to keep the lines firmly in place. I am already 5,000 miles in this summer and love the upgrade.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
