I wanted to change out my brake lines for steel lines. Does anyone know the stock hose lenghts(all three)? What length would I need for a two line conversion? I have a stock handlebar setup. Any help is appreciated.
Dunno the size, but... murpskits.com sells Spiegler SS brake line kits (2 or 3 line) all sized properly for the Concours and comes in different colors. -- Steve Smith, #3184 COG Northeast Area Director (somewhere in south central CT)
If you're not living on the edge, you're taking up too much space.
I wanted to purchase some custom goodridge lines. So I needed to know the length's of the stock ones. Or the length of the longer "two style" lines. Murph's is nice but I wanted something different.
You may want to touch base with Goodridge tech support. I recall someone worked with them to come up with a set for the C10. The ZG models are not listed in the Goodridge catalog, but they may still have the info around. -- Steve Smith, #3184 COG Northeast Area Director (somewhere in south central CT)
Aside from the lengths, you will also need to ensure the fittings have the correct angles. I just replaced all my lines last month with some from Murph's, and if I have gotten them mixed up they would not have fit because of the different angles on the fittings. Later, Charlie
Also keep in mind if you ever want to fit bar risers or a different set of bars you will want slightly longer lines on the front. Colin Prior Cogmos Committee Chairman Lake Forest Park WA COG#7767
Thanks for everyones replies. I went over to SunnySteve's on sat & he assured me that it would be alot easier to order Murph's kit. He is using Russel's on shouldabeen now. Murph's kit comes w/all the bolts & wahsers etc. I found that new EBC pads and a system bleed was all I needed for right now. Nice two finger lever action. Text
