So is the spacer a different width on the bottom shock mount?Jim Snyder said:The bushings in most shock absorbers are hardened steel and very difficult to drill with normal bits.
Pbfoot said:So is the spacer a different width on the bottom shock mount?Jim Snyder said:The bushings in most shock absorbers are hardened steel and very difficult to drill with normal bits.
Thank you Fred!! You the man as usual. I can't wait to get this baby installed. I think I wil use 17-4 stainless.fred-houston said:Sometimes a picture is worth a thousand words.
The one on the right is the stock C-10 shock, the other two are a ZZR and a C-14. I think the one in the middle is the C-14 and the one on the left is the ZZR, but I might have those two turned around.
Dennis, all you need to mount the C-14 shock is a 20mm by 30mm bushing with a 10mm hole, which I know is a piece of cake for you to make. The top mount you just drill it out to 12mm, but I have read where some just used the stock 10mm C-14 bolt with no issues.
I would appreciate that. Want to have everything finished before the swap as I am working in an apartment complex parking lot.fred-houston said:Dennis it is not much, just a couple of mm's. I just took a little off both sides until it fit. I can measure my spare when I get home tonight.
Pbfoot said:I would appreciate that. Want to have everything finished before the swap as I am working in an apartment complex parking lot.fred-houston said:Dennis it is not much, just a couple of mm's. I just took a little off both sides until it fit. I can measure my spare when I get home tonight.
Thank you, sir!fred-houston said:Pbfoot said:I would appreciate that. Want to have everything finished before the swap as I am working in an apartment complex parking lot.fred-houston said:Dennis it is not much, just a couple of mm's. I just took a little off both sides until it fit. I can measure my spare when I get home tonight.
Dennis, I did mine freehand, and I measure it at 27.9mm. I am willing to bet you will be safe at 28mm if you are machining it.
