Here's a fun one.. my customers unit isn't actually leaking from the o-ring. . Its leaking from the plug.. I can watch oil bubbling up around it...
You are correct about ur ASSumptions....I am making a few assumptions here and I will lay them out, also in advance, if my assumptions are incorrect please accept my most humble apologies:
- You are a professional motorcycle shop.
- You found this forum and likely other fourms and are looking to ask for help.
My opinion:
- If I take my motorcycle to a shop, I hope they are not trolling forums for advice. They should know how to service the bike or admit it and let the owner make the decision.
- If I take my motorcycle to a shop paying the hourly wages they will tell me in short order if they cannot help me instead of bleeding me.
To be fair I made assumptions on this post and I am willing to hear what I missed.
Yes it was a simple statement that I figured I would get "yep they do that" or "no never seen that before w this sensor "I thought his intention was to share new info with folks that would be interested in hearing it.
I had a Dodge neon that had a leaking oil pressure sensor that sent oil INSIDE the wire and was filling the ecm with oil, even though the ecm was physically higher. It makes sense to me.
I was just going to say this... i was a Dodge tech, I've seen OP switches leak oil thru the connector a few times. Wicking oil all the way to the PCM is crazy tho.I thought his intention was to share new info with folks that would be interested in hearing it.
It WAS crazy. I pulled the pcm and oil ran out of the connector. Never heard or seen anything like it.I was just going to say this... i was a Dodge tech, I've seen OP switches leak oil thru the connector a few times. Wicking oil all the way to the PCM is crazy tho.
I've seen the oil wick up the stator wires all the way to the plug on a few bikes...It WAS crazy. I pulled the pcm and oil ran out of the connector. Never heard or seen anything like it.
Yep its actually bubbling up around the plug ... I have a pic but don't see how to load a pic on my postAre you saying that oil is leaking out the body of the exhaust cam sensor? I've serviced literally hundreds of C14's and have never seen this happen, but that doesn't mean it isn't possible.
Yep.. free because I was just after some info about this oil leak that Google told me about... n maybe ordering the new parts if the customer wants me to get into it... he's selling it n wanted the leak "fixed" ...Oh, I see you are on a free account, never mind, you probably don't have the photo feature on your account.
yes its a close up of the plug to show the oil seeping/bubbling up around the plug itself....I'm not understanding this photo. It doesn't look like the exhaust cam sensor to me. Is that maybe a really close up shot of just the end of it?
Here is a photo of the exhaust cam position sensor on the front of the engine block.
It's 100% coming from the plug... that pic was after I cleaned the entire area w a cleaner n my pressure washer.... I could literally watch it bubble from the plug...Clean it up with brake clean, and then spray some talcum powder on it and run the engine, you'll see exactly where it's coming from. If it really is leaking from the sensor body, you'll just have to replace the sensor.
Bingo....2000 and I believe 2001 ZX12Rs would leak/blow or push oil through the stator wires and leak out where they plugged to the rect/reg under the rear seat. I have been a professional motorcycle mechanic and dealer for almost fifty years and WILL use any means available (including internet and forums) to help me help my customers. I have found many unusual/(possibly)unbelievable things during my career.
