Does the final drive drain plug use the same size washer as the engine oil drain plug? Do you re use the washer several times before installing a new one? Rick
kawasherpa said:Does the final drive drain plug use the same size washer as the engine oil drain plug? Do you re use the washer several times before installing a new one? Rick
